32 Channel Microphone Preamp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th March 2011, 08:51 AM   #1
Volpe42 is offline Volpe42  United States
Default 32 Channel Microphone Preamp
A friend of mine as asked me to look into building him a Balanced Tube Microphone Preamp for his Digital Recording Studio (if I remember correctly he uses a DAC), and I am wondering how much of an undertaking this would be?
Old 8th March 2011, 09:25 AM   #2
Brouilly's Avatar
There are quite a few mic preamp threads out there already, some are really informative, there will certainly be enough there to give you a good idea.
Antonio and Ruffrecords have been working on a 10 channel mixer for a while, and that seems like a big task.
http://www.diyaudio.com/forums/tubes...ube-mixer.html
32 channels would be a mammoth undertaking.
Charlie
Broke solderer with delusions of grandeur
Old 8th March 2011, 04:29 PM   #3
ruffrecords's Avatar
Yes, a bit more information would be helpful. Is this just 32 individual mic pres or is there some mixing to do as well?
A 32 channel tube mixer would indeed be a challenge!
Cheers
ian
Old 9th March 2011, 01:49 PM   #4
My understanding is that he just wants the preamps.
Old 9th March 2011, 02:12 PM   #5
artosalo's Avatar
Don't you have any specification ?
Old 9th March 2011, 03:01 PM   #6
kevinkr's Avatar
Yeah you need that.. Here are some questions that I would ask, and I expect ruffrecords probably has many additional useful suggestions, but at a minimum I would ask:
  • Do you need (switchable) 48V phantom power?
  • Do you want input transformers, and if so what part of the budget can you allocate to their purchase?
  • What features are on the mixing board that you don't need to duplicate? (EQ, polarity inversion, etc?)
  • How much gain is required, and how do you want to control it?
  • What is the noise floor, typical and peak output levels of the microphones being used? (Gain requirement, noise floor and overload margins, any special supply or load impedance considerations?)
  • Do you need balanced output? (Since this is a tube pre, that probably means another transformer.)
  • Stick to commonly available tubes like the 12AX7, 12AT7 or go for something more exotic and hence expensive?
  • What sort of packaging/chassis format do you envision as being ideal? (4 ITU rack chassis with 8 independent channels sharing a supply for example or ?)
This sounds like a really, really big project to me..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Stromberg-Carlson AU-32 distortion in preamp Westside Tubes / Valves 0 15th November 2010 02:09 AM
FS: LS-32 Preamp board with 6H30Pi Andypairo Swap Meet 5 8th March 2006 07:34 AM
microphone preamp svokke Tubes / Valves 18 3rd December 2005 02:01 AM
decoupled 32 channel splitter Muziekschuur Analog Line Level 2 22nd October 2005 10:23 PM
Integrated 27-32 TV center channel Hezz Multi-Way 8 19th December 2004 10:17 PM
Copyright 1999-2017 diyAudio
