Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th March 2011, 04:59 AM   #1
Question Head vs. Head
Hello to all people out there. I am in a dilemma, for what amp to get.
I am currently growing out of combo practice amps, and looking into getting a stack. I am torn between the Line 6 IV hd150, and a Peavy VYPYR. I am planning on building a cab myself, so I have options for wiring.
Is the more watts going to speakers mean that it is louder??
How big of a stack can a line 6 hold?
Can I use a full stack with the Peavy??
Some background of what i plan to do.
I plan on using some drop tuning, and want built in effects, footwsitch jack, and maybe an effects loop. Any other suggestions welcome, And the lower the price, the better, as I am saving up some money from some small gigs.
Old 8th March 2011, 06:46 AM   #2
pinkmouse's Avatar
Thread moved to more appropriate area.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th March 2011, 12:52 PM   #3
I would imagine it really depends on a LOT of factors?.
Your amp/speakers is really only for on-stage monitoring, or small venues. The main volume from your guitar should be through the PA system.
Your musical style affects it as well, stacks are mostly for heavy metal, and more for 'showing off' than anything else
Nigel Goodwin
Old 8th March 2011, 08:13 PM   #4
chrispenycate's Avatar
While in the absolute more watts will make something louder, in the general case, practically a lighter cone speaker, or a different cabinet, will often make more difference than doubling amp power. Even rigging that combo on a chair so that it's feeding your ears rather than your knees can make an enormous difference, far more than just more power.
So, why do you need this extra loud? Personal gratification? Need for feedback to the instrument to increase sustain? Other members of the band can't hear you? (that last one's dangerous, as it tends to lead to an upward spiral) Admittedly a stack tends to spread better than a combo (memories of an outdoor festival where a mesa Boogie 1x12 was blasting a laser-straight line of annihilation through the audience, with those two places off the beam not understanding why their neighbours' ears had started to bleed) but it's a lot more transport.
So a large array of inefficient loudspeakers looks impressive, doesn't get too loud, and covers reasonably well.
But if you use a tower with six 250 watt 12" speakers, you're not obliged to drive it with a thousand watt amp. In fact, that much potential power would make you very difficult to work with. In fact, do you like the sound of your present combo? (apart from there not being enough of it, that is? ) If you know it well, and can get what you need out of it, it might be worth simply taking the speaker output and feeding a solid state booster, cheap PA amp with good specs and no expensive controls.
Then, when you gid small gigs, or big gigs with decent PA and monitors, you could leave the heavy stuff behind.
The original Marshall 8x12 contained 8 fifteen watt celestion 12 inchers, was run of a fifty watt amp, and was designed when PAs were a joke.
Old 8th March 2011, 09:20 PM   #5
pinkmouse's Avatar
Just came back to answer your question properly after the move this morning, and I see Chris has raised every single point I was going to. Thanks Chris!
Al
Old 9th March 2011, 03:24 AM   #6
I am upgrading the driver in my small combo. It works fairly well, but if i stand 50 ft away from it, and play a chord, i can barely hear it. This is not usefull if i am going to play outdoors, which is what i plan on doing somewhat.
I am playing metal, or at least hard rock type music.
Old 9th March 2011, 08:05 AM   #7
Like I said above, the power should come from the PA, not from your guitar amp - I doubt upgrading the driver will make much, if any, difference.
Nigel Goodwin
Old 9th March 2011, 09:38 AM   #8
There is no absolute rule that says all the work must be done by the PA.
Certainly there is a fashion for in-ear monitoring, keep levels down on stage, when the automatic decibel shutdown comes in you can't hear anything but the drums type concert, but it makes the musicians very dependent on technicians who are not part of the band, and they have no reason to trust to be getting it right. (Yeah, I'm often one of those technicians, and why should you trust my judgement on the final mix?) And feeling the performance in your bogy, with twenty thousand watts of sidefills, drum fill and wedges driving back into the musicians is a very physical, adrenaline-loaded experience (even if your FOH mixer has given a sigh, and is trying just to get vocals and snare drum audible through the mess).
But he obviously doesn't need this stimulus to play, as he's succeeding quite well now on a combo.
Trouble is, an AC30 can easily balance up with a 200 watt bass rig, and amplified drums. A keyboard rig would need at least 250 watts and efficient speakers to match it without distortion. Are you intending to upgrade all your back line, and your transport? If it is just occasional big gigs, much easier to hire an outdoor PA when, and only when you need it. And if you're playing festivals or opening band even that is generally covered.
As regards which amp would be best for you, the only way is to try it, if possible in the real conditions you'd be using it . Listening to it in a shop isn't the same. Hire one for a gig, get the music shop to bring one round, find a mate with one. "Sound" in this situation is subjective; we can talk about dBs, and build quality, toughness; but it's not percentage distortion or phase shift that's going to make this your amp, and you are the only person who can feel your needs.
Old 9th March 2011, 11:41 PM   #9
Enzo is offline Enzo  United States
If I can't trust you with my mix, why on earth would I hire you?
There is no law about getting the giotar in the PA, but come on, outdoors? Outdoors is the toughest room there is to fill with sound. Some guitar amps beam the sound straight out the front. That means you can hear it a mile away as long as you are on axis with the speaker. But then the rest of the guys on stage can;t hear you. Other speakers/cabs spread the sound around, great for on stage, everyone can hear. But then it doesn;t project very far.
Neither of those things fills the outdoors though. Your beamer falls on the ears of those few folks right in the path of your amp, but no one else hears you. Of your cab has a difuse pattern and the only folks to hear you are the ffront row. SO outdoors especially, you ought to be in the PA.
Old 10th March 2011, 01:00 AM   #10
Mostly, i just want to upgrade to something that does not make me look like a kid who just picked a wall mart guitar. I want to make it look like i am not a beginner.
Head to head comparison of Manger and Lowther in Acousta and Front horns David Pinnegar Full Range 3 12th January 2011 12:59 AM
motor types head to head for a TT p_ete2003 Analogue Source 20 11th January 2007 08:29 PM
Did I get in over my head too soon?!? janikphoto Tubes / Valves 15 6th November 2006 12:08 PM
Head Unit VoLCoM Car Audio 4 31st October 2005 02:51 PM
I'm in way over my head. Richie V6 Multi-Way 9 8th January 2005 09:07 AM
Page generated in 0.11286 seconds (82.89% PHP - 17.11% MySQL) with 10 queries
