Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 25th February 2011, 01:49 AM   #1
Default Guitar bass amplify
First, I have no clue what I am doing. I want to experience making this thing.
I posted a question to build a 2 cubic feet Bass Cabinet to fit Emminem 15" 300 Watts 8 Ohms. With all resposes, I decided to build a closed box with
H: 21 Inches
W: 20 Inches
D: 12 Inches
By calculation (outside), the box will have 2.19 Cubic feet. I assume this side may suit my need since the speaker and braces may reduce some internal volume (The important matter is I don't know how measure the speaker and the braces.)
I am close to finish building the box. Then, I have another question:
1) Is it possible to look for (to buy) a driver to use with my newly build box?
According to the speaker emmenem 15" 300 Watt 8 Ohms spec, I need a driver with the power of 300 watts, rigth?
2) Is there a away that I can build this driver?
Thank
Old 1st March 2011, 08:34 PM   #2
tinitus is offline tinitus  Europe
hey
your post is very confusing, and dificult to understand
Emminen ? is that Eminence speakers ?
Old 2nd March 2011, 06:31 AM   #3
chris661's Avatar
The cabinet you've made will be suited for the Eminence driver it's designed for.
Other drivers may still work in it, but the originally intended driver would probably be better.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 12th March 2011, 01:43 PM   #4
I have got all my material and starting putting thing together. Could any one give me instructions of how to wire from woofer to input jack.
the woofer comes with two plugs (connections) - Red and Black. the input jack comes with three prongs.
Chris
Old 12th March 2011, 05:13 PM   #5
chris661's Avatar
You want the tip and ground connectors. On a socket, these will be at opposite ends. Connect the black from the speaker to the connector nearest the hole, and the red to the one at the other end...
If you don't get that explanation, I'll draw something up...
Old 13th March 2011, 05:03 PM   #6
Chris661,
Thank so much for all yous instructions. Honestly, I am confused. Could you please provide draw or image.
have good day.
Old 13th March 2011, 06:27 PM   #7
chris661's Avatar
Here we go.
It's quite difficult to explain - a picture tells a few words.
Old 14th March 2011, 10:36 PM   #8
thanks so much for the pic.
I think I have to buy the same input jack in your pic so that I can use the sample from the pic. Do I need ground?
I bought the metal-input jack which comes with three foots.
Did I buy the wrong type of input jack?
what is the different between the two?
Here we go.
Old 15th March 2011, 02:51 AM   #9
Banned
Originally Posted by BuildByHands View Post
three foots.
=Stereo.
You can still use it, don't use the middle connection.
w
Using Sub for Bass Guitar Dan2 Instruments and Amps 32 28th March 2012 05:50 PM
Bass guitar amp billr Instruments and Amps 3 23rd August 2009 09:37 AM
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
tiny opamp based cct to amplify six (piezo) guitar pickups? HankMcSpank Solid State 9 23rd February 2009 09:29 PM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
Page generated in 0.09956 seconds (83.88% PHP - 16.12% MySQL) with 11 queries
