| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hi. Can someone explain the fundamentals of tube distortion (for guitar)?
I have a pretty good understanding of tube amplifiers and I know how to clip a signal but I need more info on how each stage of distortion is driven. What makes the magic? What makes guitar distortion sound compressed and layered? What I'm building uses a cathode follower (1/2 12ax7/12au7) on the front end to drive a 3-band tone stack then 4 distortion stages (2x 12ax7) then another cathode follower (1/2 12ax7/12au7) into another 3-band tone stack. This allows me to shape the signal from the pickup then shape the output. So, I have 4 triodes to clip. I plan on putting a pot between each stage because I believe each has to be adjusted precisely so they all begin to clip at roughly the same time with #4 clipping first, then 3, 2 and finally 1. I think this is how the distortion layers up harmonics as the input gain it increased. This would also explain the compression effect where the sound seems to be mashed together. The 4th stage, being clipped first, can't get any louder and each prior stage adds more and more harmonics, as they come into clipping, but don't actually add to the output level. Sound somewhat correct? |
#2 |
It's a matter of taste and design goals but generally I have found the "all tubes must clip at the same time" to be somewhat a myth.
e.g. Trainwreck amps: power amp clips way before the preamp does. When preamp finally begins to clip the last stage clips first. Even generally you hardly ever have any clipping going on in the first gain stage simply because there isn't enough of gain to drive the stage into clipping with the low magnitude guitar signal. In most high gain designs the second stage doesn't clip much either (unless you really, really push the amp) but it has a function of providing enough gain to enable overdriving the following ones. The third stage usually has significant grid conduction effect that clips the signal asymmetrically and hardly at the grid (the high amplitude signal output of second gain stage enhances this effect), then the gain and the input signal's magnitude is sufficient enough to drive the stage into almost square wavish distortion (all this while stages 1 and 2 still remain clean). In many amps you may have a directly coupled cathode follower in this position as well, which then has different overdriving characteristics than a plain common cathode amp. In some designs there may be fourth or even fifth gain stage for gain recovery after tonestack, or to even push the amp into much harder clipping e.g. Peavey 5150, Dumble, etc... But you almost never ever see the mythical "unison" clipping at each gain stage, where each stage would clip a bit at the same time. Usually the ones being later in the chain do most of the clipping and the first stages stay moderately - if not completely - clean. Then you have the filtering in between and within the gain stages which is a whole another story and an extremely important part in the overall design. Don't overalook that in light of the gain. It has way bigger effect than how much you clip and at what overall balance of even and odd harmonics. Your best bet is to take a bunch of amp designs and study them closely. That's way more revealing than trusting the common folklore about the stuff. I've found most of the common claims concerning tube amp operation to be completely incorrect in real life. The "tubes must be adjusted to clip at same time" is one of numerous examples. In at least 90% of cases you see exactly opposite type of operation. Last edited by teemuk; 17th February 2011 at 01:14 PM. |
#3 |
Also, IMHO a CF as the 1st stage in a guitar amp is a bad idea, it will have bad SNR with a typical passive pickup, that's at least one reason why you don't see it done in commercial amps.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 | |
I pretty much figured the stages need to come into clipping shortly after one another starting with the last clipping first. I guess they didn't all come on at once. I've studied some designs and see some have alot of shaping going on between stages and others have none at all and sound great. |
#5 |
Lazzer408 - Do you have a feel for how much gain can be had is such a first stage? If you can get your hands on sub circuts that work this way, try making some measurments and do what is called a "gain budget", or an anaylasis on paper. Im afraid that you will end up in the mud like leadbelly is warning about.
#6 | |
I'm building a test rig to try some different configurations before I build it into anything nice looking. I was more interested in learning from someone who knows how the stages work together. |
#7 | |
http://i406.photobucket.com/albums/p...Breadboard.jpg |
#8 | |
#9 |
Printer2 - thats pretty cool
#10 |
Myself, I like Ken's approach - hit the splitter as hard as you can and let the power tubes work it out. I'm not fond of overdriving 12AX7s - I'd rather use LEDs in the preamp.
What I used to like is gobs of B+, but you can't really do that with Chinese tubes, and you don't want to do it with NOS, they cost too much these days. Still, for the last 20 minutes, they sounded glorious! At any rate, I'd listen to teemuk, he really knows his stuff. And I agree with leadbelly, guitar signals should be boosted before they're cut. Let us know what you find when you get it together. |
| Good books on fundamentals | meconlen | Everything Else | 6 | 11th May 2010 08:47 PM |
| bipolar transistor fundamentals... help help! | oldeurope | Solid State | 5 | 7th June 2008 07:52 AM |
| Fundamentals of tube amp design | rokali | Tubes / Valves | 6 | 17th December 2007 05:55 AM |
| Please help me understand speaker fundamentals | jnb | Multi-Way | 5 | 20th July 2007 03:26 AM |
| Time alignement fundamentals | Kjetil | Multi-Way | 28 | 31st March 2004 06:35 PM |
| Page generated in 0.11648 seconds (87.26% PHP - 12.74% MySQL) with 11 queries |
