Troubleshoot help for vibrato type problem - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 16th January 2011, 05:57 PM   #1
Default Troubleshoot help for vibrato type problem
I've rebuilt an old Bogen CHB10a and it works fine with one problem!
Sound is nice, just what I want/expect but when I turn the volume up past about 8 or so I get a vibrato type sound out of it.
I have not run into this before and I am hoping someone with more experience might know where to look.
I've attached the Schematic and a very small mp3 (zipped) file so you can hear what's going on.
I replaced all components with new or NOS for some of the foil caps. Everything was on value when I put it in.
Thanks in advance for any help or suggestions.
Chris
Old 16th January 2011, 06:03 PM   #2
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
Possible power supply decoupling problem?
How do I put the smoke back in this thing?
Old 16th January 2011, 06:29 PM   #3
M Gregg is offline M Gregg  England
A few ideas.
Check value of B+ rail when Warble happens does it "dip".
What is S2? Does the problem change if switch positions are changed?
Also what happens if tone control is changed?
Check is C7 cap faulty?
Can you post PSU schematic?
M. Gregg
Old 16th January 2011, 07:13 PM   #4
Since the schematic says it's modified, it makes it harder to know where to start -- but it sounds like a classic case of inadequate decoupling in the power supply, so that feedback occurs back to an earlier stage when the gain is advanced beyond a certain point. I would use two separate isolated B+ points for the first two stages to confirm if this is what's happening.
Dave
Old 16th January 2011, 07:32 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It looks like feedback through power supply, but may be HF oscillation of the 1'st stage as well. Try 68K grid leak resistor.
Add PS filter capacitance in parallel to existing one and check if frequency of vibrato goes lower, or if it stops.
The Devil is not so terrible as his math model is!
Old 17th January 2011, 04:45 PM   #6
Thanks All.
I'll take a look in the places you suggest and let you know how it turns out.
Old 25th January 2011, 05:40 PM   #7
Thanks for the help folks,
Replacing the PS filter Caps one at a time fixed most of the problem. Adding the 68k Grid Leak resistor cleaned up the rest but did make it more sensitive to picking up radio signals!
Looks like I have more reading to do.........
Thanks again.
Chris
Old 25th January 2011, 06:21 PM   #8
Wavebourn's Avatar
That means, your input stage must be shielded.
Try to cover it by grounded foil to check if it helps, then construct a shield made from thin copper, or even from tuna can metal if you can't find copper.
Old 25th January 2011, 11:38 PM   #9
trobbins's Avatar
You're running grid leak bias on first stage. That may be quite temperamental. I suggest temporarily changing to a standard cathode bias configuration (eg. 1.5k or 2k2 bypassed with 25uF 16V) to see if that is the major influence.
Also use say a 68k grid stopper placed on the input valve base. You may also need to use a shorting input jack if you don't have a low impedance pickup connected, or a phono output stage connected.
As per post above, insert an RC decoupling of the power supply rail from PI stage to input stage.
Ciao, Tim
Old 25th January 2011, 11:59 PM   #10
Wavebourn's Avatar
My bad; I meant grid stopper 68K, not a grid leak resistor.
Sunn Sceptre: Weak Vibrato Cause? slor Instruments and Amps 3 25th October 2009 09:45 PM
Obliterate, delete Vibrato or Reverb circuit in blackface-like amps german23 Instruments and Amps 6 23rd September 2009 04:23 AM
Fender Twin Reverb VIBRATO PROBLEM - weak vibrato gibsonripper Instruments and Amps 2 19th January 2008 05:23 AM
wavy vibrato-like sound when amp cranked 9am53 Tubes / Valves 4 19th May 2005 01:23 AM
help with this Vibrato Circuit nordine Instruments and Amps 16 18th August 2004 06:05 PM
Copyright 1999-2017 diyAudio
