This is a classic QSC style amp with the grounded collectors on the outputs. If your outputs check good, then you've most likely got DC coming out of your op amp (causing DC on the output). The op amps fail frequently if an output fails because they are DC coupled. Check for unbalanced supply rails to the op amps first as this is the most frequent source for trouble in these amps. Also check caps. Good luck.
