Guitar amp with 6P6S (6V6) and probably 12AX7 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd January 2011, 09:44 PM   #1
Default Guitar amp with 6P6S (6V6) and probably 12AX7
Hi everyone,
I'm from Poland and it's my first post here so I ask for lenience as I am a beginner with tubes
So, I decided to build my first low-power valve guitar amp. In the past I built some amps but I haven't used tubes inside them since now. I have one Russian 6P6S tube (it's electrically identical with 6V6) and it will be a base for a power amp.
As a preamp I would build this, if possible. I mean if it's possible to match the power amp on 6P6S (it's a must, so if I have to change my idea I'd rather change the preamp). I would be very grateful if someone here could help me with a schematic for this
Or, if someone has a different idea, especially better than mine I would appreciate it :P
EDIT: Sorry I haven't mentioned it: it will be for a BASS guitar...
Greetings
Old 3rd January 2011, 12:49 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hi, sorry, but we have technical problems with your post
we are working on it
moderation
seems ok now
sorry for the delay
Old 3rd January 2011, 07:02 AM   #3
No problem, it's good to see it at last... :P
Any idea?
Old 3rd January 2011, 04:29 PM   #4
Cassiel is offline Cassiel  Libya
Tinitus plays bass, is 5 Watts enough for bedroom practice?
Your preamp does not have a feedback loop. I think SE (one output tube) with no feedback isn't a great idea for a bass amp.
Old 3rd January 2011, 04:50 PM   #5
Dragondreams's Avatar
I play bass too, and 5 watts is MORE than enough for bedroom levels. One of my own amps runs an option to drop the output to 2 watts (using a 6N1P) and that's often quite loud enough...
Experience is what teaches us to make a different mistake next time...
Old 3rd January 2011, 04:51 PM   #6
It's a clean channel based on Fender schematic. I would like modify it to fit a bass combo. With some help of course because I'm young enough to live :P
5W of valve power is sufficient, even more - 5W valve amp (but dedicated for guitar - I'm better guitarist than bassist) mixed with a 300-Watts cabinet is the configuration of mine for a rehearsals of our band - and it's cool, I can hear myself pretty good.
Also: the amp will be powering in the combo two 8" speakers, each has only 10 Watts, so "stronger" amp won't work for me.
Old 3rd January 2011, 07:30 PM   #7
300-Watts cabinet
For guitar?
For bass?
I don't follow you, it makes no sense. Anyway for clean, tight bass a single ended topology wouldn't work. So, tube preamp+SS amp or push pull.
Old 3rd January 2011, 09:38 PM   #8
With 300-Watts cabinet it was only a example of what a tiny amp can make.
It has sense 'cause the big cabinet (300W) is only a GUITAR cabinet, for me, for playing the guitar in my band with another head of 5-Watt power which I've already bought.
This bass combo (on this 2 speakers) will work only in home (with no use of full power) to learning because (as I said before) I'm not a bassist. Maybe in the future I'll plug something bigger but it's a far far far away now...
So using the 6P6S will be a bad idea?
Old 4th January 2011, 03:51 PM   #9
Bad idea is building an amp without knowing what you're doing. Read something about bass amps and bass cabinets first. Google's search engine works well.
Old 29th December 2012, 01:03 AM   #10
maton00 is offline maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
c'mon......
what transformers do you have ,or what are in your possibilities?
Ive done this one and I have no complains.
and its very simple.
6v6 push pull guitar amp schematic sought guitar_joe Instruments and Amps 40 12th April 2013 06:26 AM
6SJ7(6J8) + 6v6 (6P6S) SE athos56 Tubes / Valves 4 23rd July 2009 07:24 AM
6V6 guitar amp design attempt Craig405 Instruments and Amps 29 2nd August 2006 04:48 PM
6V6 guitar amp... Guiness Instruments and Amps 3 24th November 2003 08:31 AM
6V6 Guitar Amp SHiFTY Instruments and Amps 2 5th August 2003 02:10 PM
Copyright 1999-2017 diyAudio
