It's worth going for it.. What wattage are you planning to run the power amp at ?
I definitely don't need the full 100W. I would be happy with 15-25 watts. I can barely crank my 1W tube amp (Firefly) 1/2 way without the wife complaining!
I know this is old but...
I'm new here-
I have a Squier 15 8in combo w/o reverb that I cut down into a head unit and fitted on removable power and a speaker out running into an Eminence legend(have to find the #'s) and a recycled Drive brand ported combo box turned cabinet. The result has been unbelievably awesome. Really clean is a little hard to achieve- vol at .5 or less, gain off, master wherever needed, treb 9, mid 3, bass 3. The gain stages pretty much go straight to Marshallesque and are balls out and keep up with a live drum kit no prob. I'm building a 412 with some Randall speakers and a plywood crate just to see what happens? I too would like to put the empty reverb portion of the board into use though there's now no room for a spring unit in the cut down head. Any ideas?
Thanks..
I'm new here-
Thanks..
Hi Cabcobbler,
The frontman 25R uses a very small spring reverb, I think if you look up accutronics ''blue reverb'' you get an idea of just how small it is. You might be able to squeeze it in.. it's about $10 at amplified parts
http://https://www.amplifiedparts.com/products/P-RAMC2BF3
