Modding a Fender Frontman 15G? - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th November 2013, 02:17 PM   #11
I think a champ would be cool but the transformers would physically stress the chassis, and I think the goal was to improve the amp. Also, a champ build would require making a new faceplate as this one has too many holes. Just upgrade the speaker IMHO.
Old 9th November 2013, 09:15 PM   #12
shanx is offline shanx  Canada
This is what sort of bothers me about a lot of the entry level solid state amps and not just this series. There are these op amp sections with tone shaping, and I am not sure if they are there mostly to compensate for an inferior speaker? This is a noisy amp, there is a bit of an odd tone to it, almost a caricature of an early fender. Clean is passible, but the ''overdrive'' is (to put it mildly) sounding like a really cheap fuzz pedal IMHO. Champs and Princetons did what they were designed to do incredibly well and surpassed their roles as student amps, remaining pertinent after decades.
Sorry I went on a bit of a rant there...but it just bugs me.
So speaker would be a definite. Verb tank too. Redesign of OD and warm up the Clean channel. Big list, more thoughts?
Old 9th November 2013, 09:30 PM   #13
Just some electronic ideas:
2 stage FET preamp at input somewhere before channel switch, maybe after 1st op amp
Princeton tone stack (or bassman)
OD channel String of multiple Ge diodes or diode connected Mosfets ( la Zendrive)
or complementary Mosfets. Add pot across clipper pair and adjust so there is come semblance of not being on or off. The present circuit hits the clipping limit really hard when you bring up the overdrive gain.
Old 27th November 2013, 08:33 PM   #14
On reviewing the schematics of the Frontman series all the way up to the 212R, I ended up with a lot more questions about the overall designs. Not that I don't understand the basic circuitry, but more questions about ''why is it done that way''? Are the design engineers at Fender content enough tone-wise with the entire preamp and ''overdrive'' that they basically recycled it from same, for example Princeton 112 Plus from twenty years ago?
Why run a tone stack through the clean channel only , but some different fixed network before the ''overdrive'' circuit...(with all sorts of fancy tone shaping post overdrive on the 212R)? That filter pre-contour before the drive is all scooped out and tinny sounding even before it gets to clipping.
There is enough issues here to contend with that if one considered modding it, that a load of stuff would get pulled and redesigned. Is it worth the time and money? I am not quite so sure yet.
Maybe a complete new designed board upgrade at that point, done from scratch...which is where I am probably heading.
Old 27th November 2013, 10:35 PM   #15
Enzo is offline Enzo  United States
The Frontman series is an entry level series of products.
What Frontman 15G are you looking at? On both the Mexican and Indonesian versions I see a split after the input stage, branching to the overdrive or the clean, then they merge, and the tone stack is common to both.
But looking at the FM212R, once again the signal path splits after the first stage, the lower branch is the clean and it does have a tone stack going into it. But look at the overdrive channel above. There are clipping diodes and tone shaping for sure, but look just left of the reverb drive, and just right of the mid contour switch, and there it is, another tone stack just for overdrive channel.
Scooped out and tinny overdrive? That is what the kids want in an amp.
Old 28th November 2013, 12:42 AM   #16
We must remember that these are marketed as budget amps with little concern about good "tone" when they were designed. Features, cost, and marketability were the top priorities, if you want a practice amp that happens to sound great, buy a Vox Pathfinder, and upgrade the speaker to a Weber. With these fenders, they are best suited as second amps for a budget stereo setup, children's practice amps, or cabinets for tube builds or extension speakers. We would waste more money than it's worth to upgrade these amps, just use them as they are, and maybe upgrade the speaker, but dont try to mod their garbage PCB's and destroy the amp in the process.
Old 28th November 2013, 01:54 PM   #17
Apologies Enzo, I did not comment correctly on the tone stack. What I should have said was the tone stack(s) only happen post clip, when overdrive is engaged. The pre-shaping filter is ''fixed'' not variable before the distortion circuitry.
You and pbarnell are right, that is why I decided to do a different design-build. I ''pulled the plug'' on buying the 25R, even at $100, as it would only be the enclosure being used (and maybe the transfo). I will focus on ''good tone'' with a bit different approach. Thanks!
Old 28th November 2013, 07:56 PM   #18
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Because it works.
or ... you can't argue with success
Or, to qualify these apparently bold statements:
*Natural selection*
which in this case means:
this is a cutthroat competition Market ; whatever you make, if it sells appreciably less than others, dies a "commercial" death.
So the survivors are:
* 10/15W amplifiers (because that's "enough") , as in: 2W amps are too weak and above 20W become more expensive than what kids expect to pay
* SS beats tubes BIG WAY, costwise
* cheap 6" speakers are about the minimum, cheap 8" still affordable and "good enough", cheap 10" are on the edge. Forget a good 10" or any 12" there.
* cabinets should be small/light enough so a kid or teen can easily grab one in one hand, a guitar or bass in the other, put some cables and pedals in his backpack and still be able to travel on public transport or not be a nuisance to somebody who gives him a ride.
*the whole shebang should cost $50/100 , not much more.
Under those strict conditions, it's very hard to deviate from the average beginner amp design.
FWIW those small amps can sound VERY good, problem is that beginners aren't savvy on getting the best out of them.
Just 2 examples:
1) ZZTop ripped the guts of the smallest , entry level Marshall amp, the Lead 12 (a.k.a 3005 or 5005) , mounted them in racks , and used them live and in studio, for thunderous sounds.
Yes, they used the line out to drive huge PA type power amps and lots of 4x12" cabinets .... but didn't touch or modify the circuit, because "it was a power or speakers problem, not an EQ one"
2) here's a clip from a Australian friend.
Believe it or not, the guitar sound you hear comes from an overdriven Fender Squier 15 amp, 8" speaker, close miked with an SM57 and fed to the PA.
The walls of Marshalls are used as props, disconnected .... or it would be impossible to play in that stage, and sound mixing would be chaos:
Beyond Salvation - The Angels - Live 1990 - YouTube
Old 28th November 2013, 08:59 PM   #19
Hi JM,
Thank you for that, it's sort of what I thought too.
The Squire 15 sounds better at least mic'd like that...and I believe it sounds better than a Frontman, maybe because the circuit
Old 28th November 2013, 09:05 PM   #20
Let me see what I can come up with..
Fender help Docc25 Instruments and Amps 3 2nd January 2013 10:18 PM
Fender 15G: why FET in front of TDA2050? scooperman Chip Amps 9 25th August 2011 12:27 AM
Frontman 65R /Bandit 112 schematics Elektor78 Instruments and Amps 3 1st May 2010 03:31 PM
Fender Frontman 15g broken Jpoole908 Instruments and Amps 8 3rd June 2008 02:34 AM
Severe humm in Squier Champ 15G guitar amp by Fender fortuosity Instruments and Amps 11 14th September 2005 02:26 AM
Copyright 1999-2017 diyAudio
