Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 12th July 2003, 03:32 AM   #1
Send a message via AIM to travis
Default A/B/Y and hum in guitar amps
i had to switch to playing drums because nobody will play drums for me, so i've lent my amp to my friend so that he can play through his amp and my amp at the same time. he puts his guitar into a line6 delay modeler and plugs my amp into the left-out and his amp into the right-out. anyways, one of them amps is humming like crazy and neither of them hum that much when they are alone. could it be that the two heads are sitting on top of each other? or cos they are different impedances or what?
donuts
Old 12th July 2003, 03:55 AM   #2
JOE DIRT®'s Avatar
travis you might have got it correct as all the variables of your gear are unknown
I experienced major setup problems when i was in the business with some equipment....some amps are herendous for causing problems with other equipment...if the amplifiers are fine by themselves then its an issue....but if it this happening in one location then the power feed could be it
DIRT®
Old 13th July 2003, 06:42 PM   #3
Travis,
I would suspect an earth loop introduced through the two heads being connected together through the signal earth from the line six. I would break the ground in one of the signal feeds with a isolation transformer.
ciao
James
Old 13th July 2003, 07:31 PM   #4
so if i made a buffer and connected its output to both amps, it would probably hum?
i will make something like this, with three switches: left on/off toggle, right on/off toggle, and switch to turn them both on and the same time. CMOS!
donuts
Old 13th July 2003, 07:47 PM   #5
Hi Travis,
That is a nice buffer design! Should do the job nicely as all possible earth loops between the pieces of equipment are broken.
ciao
James
Old 13th July 2003, 09:18 PM   #6
is this how it would look with out all the extra mumbo-jumbo?
i want to make sure i understand what's going on. how do i go about picking good specs for the transformers?
donuts
Old 14th July 2003, 01:45 PM   #7
Travis,
You have the drawing right. However for your scenario you could get away with just one transformer as you only need to break one ground connection. You would need a normal 'line level' transformer 1:1 ratio meduim impedance.
A typical broadcast line transformer would be excellent but you don't need something that fancy any standard line level transformer will work well with electric guitar. Voice or keyboards require something a bit better.
James
Old 14th July 2003, 03:36 PM   #8
thanks, guys.
donuts
Guitar Amps mwcontract Tubes / Valves 6 24th August 2007 12:48 AM
Guitar amps harrygrey382 Instruments and Amps 25 7th July 2007 06:35 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
guitar amps electro samurai Solid State 2 5th May 2004 02:32 PM
Op Amps in Solid State Guitar Amps MrGuitardeath Instruments and Amps 1 11th February 2004 07:43 PM
Page generated in 0.10176 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
