Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st September 2010, 01:04 AM   #1
Default Alembic SF-2 preamp schematic?
I looked everywhere on the web and I can't find a schematic for this preamp.
Old 21st September 2010, 08:22 PM   #2
I don't have a schematic of this either, but supposedly it's just two second order state variable filters.
Nice gut-shot by the way, hadn't seen it before. But the amount of opamps on there supports the theory. it's two channel, and each channel has a filter and something of a mixer. You need four opamp stages for each filter (which can be switched two LP, HP and BP very easily, in fact you can use the different outputs at the same time), some input stuff at the beginning, some mixing stuff on the end. And some railsplitting, because it is fed a single DC voltage. That should be it.
They are not know for fancy-nancy circuitry, just very high quality circuitry
The F2b is two channels of a fender input stage, the F1x is one of those channels with a crossover tacked onto it.
I can especially recommend the F2b, with a proper tube it sounds fantastic!
Oemptempa petoempetapap
Alembic F2-B phil mailloux Instruments and Amps 101 12th October 2011 02:07 PM
Help on sonic frontier sf line 1 preamp mgm31 Tubes / Valves 1 27th March 2009 10:35 PM
Alembic SF-2 Super filter Schematic ? FUCHSAUDIO Instruments and Amps 7 29th July 2007 07:32 PM
Pre/PS ala Alembic croat47 Instruments and Amps 3 16th March 2006 01:50 PM
Alembic F-2B mbonus Tubes / Valves 3 3rd March 2006 04:55 PM
Page generated in 0.06859 seconds (67.02% PHP - 32.98% MySQL) with 10 queries
