Adding Clean channel to AX84 P1-Ex - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd August 2010, 03:50 PM   #1
Default Adding Clean channel to AX84 P1-Ex
Hi All,
I have an AX84 P1-Ex built and running great. I am now in the process of building some stom boxes for fun. My problem is that with the P1-Ex, if the gain is turned down to get a clean signal, there isn't a great deal of volume. I am thinking about adding a separate preamp to run as the clean channel.
Being a novice (I can build, but have not enough knowhow on designing yet), can anyone give me some ideas about how to achieve this? Can I add a separate preamp to switch to for clean? Could it be something like a simple solid state?
Many thanks,
Robin.
Old 3rd August 2010, 05:47 PM   #2
Cassiel is offline Cassiel  Libya
Hi Robin,
It won't work. The SE EL84 guitar amp wasn't designed for loud clean sounds. Your only choice is to buy a high sensitivity speaker (no less than 100dB/m) or plug it into a 4x12 cab.
Old 3rd August 2010, 06:24 PM   #3
A feedback loop will also help but not much, copy the second gain stage from the Champ 5F1 schematic.
AX84 Clean Preamp mikasu Instruments and Amps 8 18th March 2010 11:35 PM
Shop Clean Out IMSTOOPID Swap Meet 27 16th November 2009 02:49 AM
good begginer project (ax84 v.s. boozhound) eisenhower Instruments and Amps 9 4th May 2008 02:46 PM
Clean crossovers Clipped Car Audio 78 24th March 2008 04:55 PM
What to use to clean corrosion? still4given Solid State 2 14th March 2005 06:42 PM
Copyright 1999-2017 diyAudio
