| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#1 | |
Hi!
I've just joined this forum and read through countless posts made here, trying to learn how to eventually build my own solid state guitar amp. I found an interesting post from a thread from 2007, so I cant really post this there... haha But I will quote this specific post I am talking about - Quote:
This is the circuit "Minion" is speaking about ![]() Now I play in a hardcore metal/punk band so I thought this could be the perfect first build that I could actually put to use and if I like it I can go on to build a preamp and combine this schematic into it for a gain channel? I would just appreciate it if someone could help me out a bit and help me read this diagram... Like set me on the right track toward my final goal and stuff oh btw I'm planning on becoming an electrician of some sort so pretty much anything I build is beneficial I think, is anyone here an electrician for their career? |
#2 |
I just spent some time finding a program and drew up this schematic, is it the same as the one I posted previously? and are the components accurate? I'm not sure if I even drew it right...
![]() I'm struggling to understand how this works, Its a distortion unit but the potentiometers are only at the input and output? so how does the distortion level change? anyways again any help is very much appreciated |
#3 |
I expect the pot on the input would change distortion levels, and the one on the output will simply be a volume thingy. I'm not much use at interpretting circuits, so I can't say much else...
Welcome to the forums, anyway. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 |
Oh... thats how the pots are drawn, thank you
#6 |
I was a factory electrician/maintenance man for a while before I quit. Doing nothing/playing music, fixing things for hobbies now. Electrician pays better than electronic technician because you can kill yourself so easily. Also there is slime in the pump pits. Wow, what a twenty first century thing, upper case R for resistors! I'm still trying to find out what "m" means on capacitors, changes depending on decade, continent, maybe what school you attended in what language. Pretty good first job on reading artwork. Look at music-electronics-forum.com if you are interested in guitar amps only, they don't have much patience there for hi-fi equipment, organs, keyboards or other girly things. I was banned. See my signature for my effeminate interests- all except I am a guy and am totally AC. Oh, I forget-that is "bloke" in Austrailian. What is the adjective form of "sheila"? Unless any women get upset, I prefer the company of women, as long as they have interesting hobbies.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 16th July 2010 at 12:33 AM. Reason: speak austrailian. |
#7 |
hahaha your post made me laugh so much, then I see the end "edit, reason: speak australian. hahahaha...
#8 |
You did a pretty good job of translating that layout into a schematic. The device uses one of the oldest tricks in the book of guitar distortion devices. That is to use back to back dioded to clip or square off the signal. In this case the designer has elected to put the signal throught that process 4 times. More is better ? right.
#9 |
Something to try (I did this on my old (31 years) SS combo) - add an output transformer. I used a 30VA 12-0-12 torodial. Put the amp across one winding, the speaker on the other. Took the harsh edge off the speaker, gave a more valve-y sound. Might not be what you're after for heavy metal, but sounds nice for other stuff...
#10 |
Yeah I'm still trying to work out how everything works, so this is diode clipping, that makes sense
Thats an interesting idea Chris, I might try it sometime |
| Page generated in 0.10809 seconds (79.64% PHP - 20.36% MySQL) with 9 queries |
