Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 15th June 2010, 03:27 PM   #1
nkg is offline nkg  Australia
Default Building fender 6g15 from scratch
Hi All
I am building a Fender 6G15 from scratch I can buy clone power transformer but would prefer to have separate heater supply to switch on first before B+ as it a silicon rectifier . The circuit diagram doesn't give voltage of power tranny secondary only 300 volts after the half wave rectifier and I am at a loss as how to find the RMS voltage of the of the secondary if someone could help with the math as I would prefer to get one wound . The second question I don't understand why did fender used 3 diodes in series as half wave rectification .
Thanks Nigel
Old 15th June 2010, 05:15 PM   #2
firechief's Avatar
I took the liberty of attaching the sch. better for people to comment.
Old 15th June 2010, 08:23 PM   #3
gain-wire's Avatar
If I recall correctly, you divide the unrectified voltage by the square root of 2. this gives you your RMS voltage, but bear in mind this is a LOADED voltage, what you want will have to be slightly higher than that. So take 300V, subtract roughly 3 volts for the rectifier diodes, so you have 303V peak divided by 1.414 equals 214.3V RMS.
Now you can find the turns ratio if you need to.
Also, don't worry about that B+, it will work even if it's off by as much as 30%.
two more volts or three less volts is no problem. The only thing you have to worry about is exceeding any maximum voltages like the capacitor voltages or Plate voltages.
The reason why you see a chain of diodes of early circuits like this is because Germanium diodes didn't have a very high Vforward max. So, they put a few in series to increase the overall Vf rating of the whole rectifier.
With Si diodes, it's not a problem, at least not with 1N4006 or 4007 in your case.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 16th June 2010, 12:25 AM   #4
Enzo is offline Enzo  United States
Instead of a separate heater supply, just add a switch to the B+ winding. A standby switch so to speak. Main power on starts the tube heaters, then flip teh B+ switch.
But that is really not necessary. The tubes are under no stress. After all, these things have been around 50 years without burning up tubes, so I doubt they would start now.
Old 16th June 2010, 12:56 AM   #5
firechief's Avatar
OK This thread is going in the right direction,. Gain-Wire is right about the B+ and the diodes, and Enzo is right about not needing a seperate filament transformer. Nigel, got any part's yet?
Bob
Old 16th June 2010, 05:04 AM   #6
LC Capacitor-Input Filter
Old 16th June 2010, 11:51 AM   #7
Hi
Thanks for your replies . I have made the chassis I got an accutronics tank the valves and caps and ordered the opt and choke . I was going to switch the power on via 2 switches the first turns on the heaters the second switch is wired to to the first switch so no matter which switch is flicked on first the heaters will always come on first I saw this idea in the tube amp forums I understand tubes are rugged little critters but they are all nos and getting expensive and ss diodes do come on with a bang unlike tube rectifiers but wanted to try keep it as original a possible . I am making this to go with my pro junior which I have rebuilt to make it harp friendly .
Thanks again Nigel
Old 17th June 2010, 02:59 AM   #8
gain-wire's Avatar
Originally Posted by nkg View Post
Hi
euh... I don't want to dissappoint you, but no, the heaters will not come on first in one of the possible situations. That is if you flick the Hi-Voltage switch first then the Main switch, the heaters will come on at the same time as the Hi-Voltage, which is what you were trying to avoid. Not that it's bad, but true, I'd rather have my eleven seconds thank you before someone drags me out of bed.
It will however prevent the user from turning on the Hi-Voltage alone.
Thanks again Nigel
Original in what way? do you mean looks or functionality?
Old 18th June 2010, 01:53 PM   #9
No gainwire you won't disappoint me because if you think about it the mains and the heater transformer are wired to first switch . When the first switch is turned to the on position and the second switch is wired to the first switch and it is in the off position then there can be no current to the second switch and seeing the second switch provides current to power transformer there is no B+ voltage .
And to answer your second question original as in functionality as the 63 reverb is still regarded as the better design than the reissues .
Nigel
Old 19th June 2010, 05:12 AM   #10
Then why add the non-original power switching system?
Building a room from scratch Professor smith Multi-Way 19 25th May 2009 03:05 PM
Fender 6G15 Reverb Question bluezrider Parts 1 21st February 2009 07:00 AM
Building a Fender 5E3 Deluxe from scratch. peritus307 Tubes / Valves 18 28th April 2007 01:07 AM
My Fender 6G15 is sick bassman314 Instruments and Amps 8 29th January 2007 02:54 PM
Fender 6G15 clone layt Tubes / Valves 2 12th March 2006 10:59 AM
Page generated in 0.13149 seconds (78.98% PHP - 21.02% MySQL) with 11 queries
