Post your Musical Instruments here. - Page 11 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 22nd April 2011, 03:28 PM   #101
kec is offline kec  United States
kec's Avatar
2004 MIJ Burny LP...
MSI E350IS mITX > Foobar > SPDIF > miniDSP 4X10 > Crown XLS1000 > ?
Old 30th May 2011, 02:03 AM   #102
Bad case of GAS here, two strikes in two weeks.... first bought a Yamaha FS720 cause I needed a better acoustic, fantastic sounding guitar for less than AUD 400, the neck's a little thin, but I'll get used to it; went to the local guitar shop to buy a stand for it & came out with a J&D 5 string acoustic bass (Like the picture but all black) - this one's a monster - sounds great acoustically, great fun to play. The electronics aren't so good, I suspect they've jammed in a cheap guitar preamp & tuner, the tuner doesn't really work on the low strings, & it didn't sound that great through an amp, but I didn't play with the controls much. But pretty good value for AUD 320.
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 7th June 2011, 08:06 PM   #103
I have been wanting to post some pictures of my Woodshed Studios days.
So here some from before,then and now.
These pictures show most of my arsenal but not all of it!
Enjoy DIYer's! jer
Old 7th June 2011, 08:08 PM   #104
Here are the rest!
jer
Old 17th June 2011, 03:27 AM   #105
John C.
Old 9th July 2011, 02:21 PM   #106
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
got an idea
Old 9th July 2011, 03:54 PM   #107
assembling
Old 9th July 2011, 05:10 PM   #108
and this is what it looks like
no paint yet
Old 9th July 2011, 05:40 PM   #109
benb is offline benb  United States
Here's (one of) my latest acquisition(s):
It's a "Howard Classical Series by Baldwin." Saw it at the thrift store around April for $300, and by June it was $22 and I figure it's worth that for the parts. The worst part is it weighs just about as much as an upright piano, though 90 percent of that is the wooden case.
This thing uses '80's (70's?) technology, all thru-hole parts (there's a plaque on the side where it was installed in a local chapel in 1995, dunno if it was new or used then). It's got five boards about 10" square, three apparently for tone generation, each with four 40-pin chips and four 28-pin EPROMs as well as many smaller chips. All chips are in cheap DIP sockets - there's no machine-pin sockets to be seen. Only one keyboard made sound when I got it, and most of the stop buttons didn't work. I've taken it apart, reseated EVERY chip and connector, sprayed contact cleaner into the pots, and have gotten it mostly working. It has a dead battery that apparently holds user presets in RAM - when I press one of those, everything locks up, but I can "write" to one and then recall it as long as I don't power down.. "Standard" presets mostly work. By the way it acts (some stop buttons activate other stops or the tuning, which is a 6-position rotary switch from three steps down to two steps up, and these are all on the front panel circuit boards), I'm guessing one or more of the CMOS logic chips are bad. It would be cheap enough to shotgun them, but not sure if I want to try to get everything to work. Most connectors are MOLEX .1" 2x10 to 2x16 except for three cables each with 40-pin DIP headers (!), and the "improvement" in function from just taking it apart and putting it back together suggests contact reliability problems, the kind of thing you don't want deal with on something with this many connectors. A feature or two that worked a week ago doesn't work now.
I'm about halfway ready to scrap it for parts and maybe make a roll top desk out of the cabinet, even though I have no use for a roll top desk.
Old 9th July 2011, 05:49 PM   #110
pictures with bass
Signals from musical instruments in time domain PMA Everything Else 41 27th November 2007 10:31 AM
Aussie musical instruments technology - the didgeridoo jackinnj Instruments and Amps 0 12th July 2005 02:35 AM
ICE/ class d amps used for PA/musical instruments? knutinh Class D 76 24th March 2005 05:49 PM
Musical instruments and equipment one_happy_hippy Swap Meet 0 10th August 2004 05:21 PM
Call for Musical Instruments forum board bob4 Instruments and Amps 41 22nd November 2002 10:36 PM
Copyright 1999-2017 diyAudio
