Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th March 2010, 12:51 AM   #1
Default First little amp project
My first amp project: A small 386 IC based battery powered guitar amp. All the components were either scavenged or picked up at radio shack. Total cost was around 15 bucks. The enclosure is a .50cal ammo can, 4 1/2" 8 ohm full range speakers in series. Powered at 12v by 8 AA batteries. I was a little frustrated that I couldnt find a 5k pot with a short stem but it's not hard to shorten the stem and epoxy a knob on.
It sounds OK... has volume and drive adjustment, and will get everything from clean to super overdrive.
Old 18th March 2010, 12:15 PM   #2
Looks like it means business!
Those potstems are meant to be cut to size I think, you can just put a knob on there with a set screw to fasten it. If you want to be extra careful, file a flat spot where you put the set screw (i never do).
Measure the stem before ordering knobs, it's usually either 1/4" or 6mm, although there are some other diameters as well (4mm for instance).
Oemptempa petoempetapap
Old 18th March 2010, 01:56 PM   #3
It's best to cut the shafts BEFORE you fit the pots, so you don't strain them. I've always cut plastic shafts with side cutters, and obviously metal ones with a hacksaw.
Likewise I never file flats on the shaft either - pots normally have either a flat all the way down, or no flat at all.
Nigel Goodwin
Old 18th March 2010, 06:24 PM   #4
I'm just planning on cutting it with a small abrasive wheel, so it shouldn't put much strain on the pot when I trim it.
Old 18th March 2010, 10:55 PM   #5
Minion is offline Minion  Canada
I get those crappy pots at Rat shack when I am desperate , I usually just cut the shaft down to size with my Dremmel and use a knob with a screw inset ...... cool looking amp though .....
Cheers
Old 19th March 2010, 07:23 AM   #6
I would use the paper masking tape (blue in the US, pale yellow overhere) to make sure nothing can make it's way into the pot (even though the fit of shaft and bearing is pretty tight, and filled with grease).
Old 19th March 2010, 09:50 PM   #7
Hmm, that's a good suggestion. I've got some knobs to put on there too, which will help keep the pots protected as well. ^_^
High fidelity Audio & My Ribbion Speaker Project FrankCashio Planars & Exotics 43 2nd April 2010 07:16 AM
DAC with DIR9001 & PCM1792A (fist digital project) dock Digital Line Level 13 29th November 2008 12:41 AM
Ideas 4 final year project in control systems & instrumentation engineering momin Everything Else 0 22nd August 2008 03:04 PM
Sherical Speakers project based on B&W drivers cheapskate Multi-Way 8 10th August 2007 11:36 AM
Page generated in 0.16563 seconds (41.87% PHP - 58.13% MySQL) with 10 queries
