Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd March 2010, 01:29 AM   #1
Default DI DC coupled outputs
Hello,
I have a question. If I design a DI box with balanced floating outputs, in where none of the outputs refer to ground, Will I have trouble if this DI box will be connected to a phantom powered +48V XLR input? My theorie is, as long the pin1 ground is not connected there is no reference to the phantom ground and the 48volt won't be seen. Any thoughts?
With kind regards,
Bas
Old 3rd March 2010, 07:10 PM   #2
Originally Posted by Sebastiaan View Post
Hello,
With kind regards,
Bas
Only a transformer coupled output can be truely floating, and would cause no problem with phantom power.
However, active DI's don't have problems with DI's either, and many can take their power from it.
Nigel Goodwin
DAC with UTC A20 transformer coupled outputs vaughn Swap Meet 3 22nd February 2010 04:24 PM
A DC coupled headphones amp Gluca Tubes / Valves 0 27th January 2010 02:08 AM
3-stage DC-coupled Ampl korneluk Tubes / Valves 9 8th April 2009 08:19 PM
Opamp that can be dc coupled ? beppe61 Solid State 37 20th January 2008 09:21 AM
Page generated in 0.06566 seconds (67.41% PHP - 32.59% MySQL) with 10 queries
