Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 28th February 2010, 11:24 PM   #1
Default Let's Design "DIY AUDIO's Versatile BASS PREAMP"
Hi Guys,
I have an Idea, how about if we design a versatile bass preamp?
Probably this preamp should have 3-4 Parametric EQ ( BASS-MID-TREBLE / BASS- MID BASS-MID HIGH- TREBLE), MID SCOOP/ SLAP Button. WE also can Vary MID CUTOFF, Bright/Ultra Low Switch, If Possible, add some Compressor.
Now, Let's talk about First STage of this Preamp.
Using FET?Or OPAMP? in buffer/inverting?
Let's build together this bass preamp, awaiting your opinion.
Old 8th March 2010, 07:08 AM   #2
http://albertkreuzer.com/pics/el/pre...eamp_sch21.gif
how about this one?
Old 9th March 2010, 12:36 PM   #3
regiregi22's Avatar
So, basically, if I hook it up to an standard amp (see gainclone), I would have what is called a "bass amplifier"? Like the one I hook to my big speakers cabinet for playing bass?
It would be very interesting to made one for my bass
Old 9th March 2010, 03:00 PM   #4
Brett's Avatar
That's all that's inside my bass heads - a preamp and a poweramp. A single gainclone won't go very loud, probably not even enough for stage monitoring in most cases as they're <60W.
Old 9th March 2010, 03:47 PM   #5
regiregi22's Avatar
But keep in mind that ours are REAL watts, not those high comercial numbers. We use to overspec the PSU, use big heavy transformers, put big capacitance or even regulated supplies (I use one). And the main chip with a good bypass and a short signal path.
All of this paired with 2 cabinets of high efficiency and power, and a high enough preamp signal.........and I think you are ready to wreck
Old 9th March 2010, 04:15 PM   #6
wahab is offline wahab  Algeria
On stage, 200W for a bassist is the minimum, as it s not even enough to
sound as loud as the guitarist s 50W amp s...
2 X 200W should do it...
Old 9th March 2010, 05:23 PM   #7
Brett's Avatar
I've never tested a pro amp that measured under spec (some MI stuff is a bit exacggerated, but not all), I'd rather have a SMPS rather than lug weight around due to silly audiophile excessiveness in the PS and considering the processing and EQ that's often involved in getting the tone you want, 'short signal path' means nothing.
Oh, and years of experience tells me that 60W is nowhere near enough except for very small pubs with low allowable SPL.
Old 9th March 2010, 05:45 PM   #8
As Brett has already said, guitar and PA use real RMS watts (as do any decent HiFi gear as well), it's only cheap junk and in-car stuff which uses wildly exaggerated specs.
There are various 'gain clone' type bass combo's about, 60W is enough for sensible playing - even in large rooms, where the PA should be doing the power anyway, the combo is only monitoring.
Nigel Goodwin
Old 9th March 2010, 06:19 PM   #9
regiregi22's Avatar
But this depends heavily on the size of the place where you are playing, how many musicians are, what style of music are you performing or what level of loudness are you willing to achieve.
Brett, I agree with you that is not needed any of the inconvenients of the audiophile reasons, so better go with an SMPS. buying an SMPS you can solve it. And don't need the diode bridge and smoothing caps.
For playing when you are practising, is OK because you dont have to carry it.
BTW, I play alone at my home the bass, and have it connected to the input of an EMU 0404 USB (high impedance instrument input, nice preamplifier). Then it goes to a gainclone with a regulated supply and big caps, 300va transformer. Then to my big boxes.
It sound really really good, I can't complain at all despite the fact that I can only control the tone of the sound by the instrument's onboard pot. Maybe too much pure and audiophile for me to really like it. That's why I need a bass preamp
Old 10th March 2010, 04:32 PM   #10
Even if you had just the preamp you could DI in to the venue PA? I think that should be a big consideration in to the design (though saying that I have a Hartke 3500 head powering 4x10" and 1x15" cabs)
Who has the "best" PCM1704 DIY board/design/kit?? bear Digital Source 10 5th February 2012 06:02 AM
DIY "Teleportation Tweak" & "CLC"? GlidingDutchman Everything Else 12 12th June 2009 10:40 PM
Diy "Hi-Fi" Bass Rig sumsound Multi-Way 11 26th November 2008 09:12 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
Page generated in 0.11402 seconds (83.57% PHP - 16.43% MySQL) with 10 queries
