Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 28th March 2010, 07:21 PM   #41
nigelwright7557's Avatar
Originally Posted by chris661 View Post
Hmmmm...
These hybrids sound interesting. The problem for me is that I'm young and restless - putting valves into the mix would mean lots of money spent replacing valves.Chris
Its usually output valves that dont last very long due to the high current.
Hybrids use a valve front end which doesnt use much current and so can last for a few years under normal use. You can pick up a 12AX7 for less than £10.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 28th March 2010, 07:24 PM   #42
Minion is offline Minion  Canada
Believe it or not a Simple Tube preamp is pretty easy to implement and not expensive and probably easier than trying to make SS sound like authentic tube ....
Might even be able to be powered by voltages allready in your amp , at its very most basic you just need a Tube ($10) and a few caps and resistors and a tube socket ......
Cheers
Old 30th March 2010, 11:59 AM   #43
...Chris
try this
Main page
http://gtlab.net/gtlab4/archives/216
http://gtlab.net/gtlab4/wp-content/u...3/soldano1.jpg
regards, Pawel
Old 2nd April 2010, 06:30 AM   #44
Have you seen this:
The ValveLiTzer: Low-voltage Tube Booster
Thought you might enjoy it. I don't know how he even gets a triode to work with such low B+ voltages but it's cool as hell.
Old 2nd April 2010, 07:00 AM   #45
chris661's Avatar
Now, that does look fun to try.
I shall listen later (eveyone else is still in bed...), but it's definitely going in my bookmarks.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 2nd April 2010, 01:32 PM   #46
Originally Posted by santonel View Post
Have you seen this:
That pedal needs a cover for the valve lol I can easily see it getting stood on with a chassis designed like that!
Old 2nd April 2010, 03:58 PM   #47
chris661's Avatar
It certainly needs something. Though I expect you wouldn't stand on it on purpose - it glows...
Old 2nd April 2010, 10:47 PM   #48
Here's some improved designs
ValveLiTzer Redux
ValveLiTzer Trifecta
I looked up those tubes (12FQ8). Apparently there's about 20 or so of them in an organ and they go in large lots on eBay for really cheap. Then again 12AX7s are a dime a dozen too which are better suited for the job.
I was wondering last night if these tubes were any good for OTL designs? Usually people parallel the tubes to get a lower impedance. 12FQ8s are a dual triode with dual plates (4 plates total). I wonder if you bought a set of 20 or so and paralleled them if they would be as good a tube for the task as what they usually use (I've heard 6SN7s are often used in OTL amps).
tube-like SS power amp rtill Solid State 47 13th April 2009 12:06 PM
SS preamp w/ tube amp awhite1159 Tubes / Valves 10 2nd September 2007 11:55 AM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
tube preamp + SS power amp. yngwie Tubes / Valves 8 27th April 2007 01:55 AM
Bi-amp Between Tube, and SS alexmoose Tubes / Valves 11 19th April 2006 01:16 AM
Page generated in 0.11103 seconds (72.85% PHP - 27.15% MySQL) with 10 queries
