| Instruments and Amps Everything that makes music, Especially including instrument amps. |
i make a 10 channel -4dB passive summing box,for hardware mixdown.
the below is some photos.have fun zang
#2 |
Dope. Tried any mixes with it yet? Have you compared digital to the analog summing?
#3 |
i have do some test.
i find something.during vocal mixdown with drum or wooden guitar,the analog summing show a nature stage than software mix and the voice is so clean. -zang |
#4 |
I planned on doing some tests of my own. I was just going to use 4 Y cables going in multiple passes. I tried it once but it wasn't as good of a comparison as it could have been. In the mean time I have thrown some weird measurements at different non-destructive editors. The one thing I found that seems to go overlooked is if you render to 32-bit float or higher you incur virtual no noise from gain adjustments and simple operations. Where if you are to render to 24-bit you are expanding the word-length from manipulation but are not expanding the container. Really I still don't know either way with the question but I think comparisons should be done with the digital rendered to 32-bit float or higher and then dithered down to 24-bit. I have no idea which dither would be the best for the job though or if dither is even needed
#5 |
i am very interested.can you talk more details? for my gear,i send the ten channel to four bus.10k 1% smt 0.125w resistor in signal summing 150k 1/2w film between tip,sleeve&ring.i am going to add a +20dB gain stage and test again. -zang |
#6 |
Well I looked up other designs at first and wanted to test some ideas out. My idea was basically to ignore the different workflows of analog vs digital and focus solely on the summing idea. I mean I really don't know if analog summing is somehow better than digital but I could see how analog in theory has seemingly infinite resolution compared to digital in a theoretical sense. I just decided to open up some balanced cables and hook them up to my lesser soundcard/interface (Delta 1010) and use a breadboard and experiment with the different methods. It became obvious pretty quick that nothing was going to measure better than a 2 into 1 double Y cable and I really wasn't bending ohms law or anything. It would be more convenient for more workflows to sum more than 8 into 4 at a time but it seems like if I want to give analog the best edge going through the A/D D/A a couple times is actually my best shot. I guess I am interested in the idea that analog summing might somehow be a higher fidelity than digital summing. But I suspect it's just that a small amount of analog smearing is pleasurable and that analytic accuracy can be subjectively judged as sounding cold.
| DIY summing ? | jayjaybee | Analogue Source | 16 | 25th July 2010 09:27 AM |
| summing rca's... | jkwylde | Car Audio | 4 | 15th September 2009 05:04 PM |
| Summing at the LTPI | memphissound | Tubes / Valves | 2 | 11th January 2008 05:36 PM |
| summing channels | ocool_15 | Solid State | 5 | 24th February 2005 07:23 AM |
| Summing inputs... | chipco3434 | Chip Amps | 3 | 1st June 2004 05:23 PM |
| Page generated in 0.09140 seconds (76.71% PHP - 23.29% MySQL) with 11 queries |
