Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 10th January 2010, 04:42 PM   #11
gain-wire's Avatar
Originally Posted by Nigel Goodwin View Post
No it's not - it's VOLTAGE transfer again, not power transfer, which would upset the sound quality. Can you give any examples? - certainly CD players don't, tape decks don't, tuners don't, mixers don't, record decks don't - I can't think of a single example? (or any reason to do so).
PU cartridges aren't 'matched', they have specific load requirements, both resistive and capacitive - which the preamp is designed to meet, but it's not the output impedance of the PU.
Well, I have always seen the typical impedance of audio equipment as 47kOhms - seems to make sense with BJT inputs, which most audio equipment has (even IC based preamps). Are you saying that the input impedance of typical preamps is actually much higher than 47kOhms, say by a tenfold? I doubt... But I can be wrong. Obviously you know more about this I do, having corrected me on the "characteristic" capacitance of the phono cartridge, which I realise doesn't have to be matched (a select few audio components actually allow this, some Sony and Marantz devices come to mind).
Anyway, this has gone way off topic from the original topic, which was guitar preamps with JFETs.
all I said was that transconductance and Gate-source capacitance were determining factors in the choice of what transistor to choose.
It's not because I know less than you that I talk jibberrish... please understand this.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 11th January 2010, 06:25 PM   #12
No, typical input impedance is roughly 47K, 100K, 220K, perhaps occasionally 470K. This is FAR higher than the output impedance of preceding equipment, which will normally be in the low single kilohms (or less).
Presumably you are confused about the output impedance of audio equipment?.
Nigel Goodwin
BF245 help please toshiba_nz Solid State 11 23rd October 2009 02:02 PM
Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc krellkraver Solid State 1 8th February 2007 03:05 PM
Which FET can replace K373 FET? Mrpong Parts 2 7th April 2006 11:37 AM
Fully complementary FET-in FET-out design Bensen Solid State 36 7th January 2006 09:21 AM
Yikes!! FET Substitution? Could use some FET Guru's here... EchoWars Solid State 15 9th February 2004 07:08 PM
Page generated in 0.06995 seconds (69.53% PHP - 30.47% MySQL) with 10 queries
