| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I made this delay for real time play.two pt2399 chips stereo module.have fun
#2 |
Very nice.
I always thought that they'd just get really long bits of wire, so the electrons would be delayed in getting around...
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
That's a stereo delay, right (hence the two pt2399's)? Looks like the datasheet schematic?
If guitar effects is what you're after, you can do some more tricks with those delay chips, add modulation etc. There are a number of diy (guitar effect) delays. I recently built the "Echo Base" which kind of emulates the Electro Harmonix Memory Man. But I've also built the Clari(not), which is a fuzz/vibrato, also using the PT2399 and a LM386 for the overdriven sound, the delay time of the PT has a LDR and is controlled by a led on the output of the LM386, rendering weird pitch bend effects. Good stuff, those PT2399's, no hifi sound quality though, quite high THD on the longer delay times.
Oemptempa petoempetapap |
| DIY 12V Delay - Possible? | DolbyR | Parts | 10 | 16th June 2006 12:18 PM |
| DIY analog delay | GrantB | Instruments and Amps | 4 | 15th November 2002 02:40 AM |
| DIY delay | zoom | Everything Else | 10 | 23rd October 2002 05:42 AM |
| Page generated in 0.07400 seconds (75.65% PHP - 24.35% MySQL) with 11 queries |
