Buzzing Volume and presence - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st December 2009, 06:58 PM   #1
Default Buzzing Volume and presence
Hi, I have designed and built a 100 watt EL34 push pull power amp for a guitar and I am having problems with the volume and presence controls. When The presence is on maximum there is a buzzing heard through the speakers. Also when the volume control is on minimum there is the same sound.
Interestingly if the presence has recently 'buzzed', the volume control will stay silent, but if the amplifier has been left for a few minutes, moving the volume to zero will make noise. Can anybody offer any solutions to this problem because it is baffling me!
The only way these controls are connected is to a star ground point which is directly below both of them. Over the rest of the range of the pots, they work fine.
Thanks for any help,
Chris
Old 1st December 2009, 10:08 PM   #2
pointy is offline pointy  United Kingdom
pointy's Avatar
are you using resistors from the pots to ground............?
Old 1st December 2009, 10:31 PM   #3
No - should I be?
Old 1st December 2009, 10:41 PM   #4
pointy's Avatar
may be if you put a 4 ohm cardon film in it may stop.
sometimes with low voltages, pot contacts act like capacitors and then if in series will change value.
Old 1st December 2009, 10:52 PM   #5
I'll give it a go! Does how good the pots are affect this - I'm using alpha pots which are supposed to be decent. Also, would adding a resistor in there alter the effect the pot has on the volume?
Old 1st December 2009, 11:16 PM   #6
pointy's Avatar
with alps you should not get the problem i was thinking it was as they use a multi contact which was designed to over come this.
but it should be ok to try as the pot should be in the order of (K) ohms and only adding 4 ohms will not change much.
Old 1st December 2009, 11:25 PM   #7
pointy's Avatar
like this........... TB-303 potentiometers
but it still only take a little oil or dust to lift the contacts
Old 1st December 2009, 11:43 PM   #8
Thanks for your help - I'll try the resistor first since I already have ~30 alpha pots over the whole amp! Good to know for future reference about the alps devices though - cheers
Old 2nd December 2009, 01:09 AM   #9
pointy's Avatar
for safety only put the resistor in place temporarily to see if it fixes things.........and then change the pot.
do not leave the resistor there as the pot is a hand control and if the resistor faults you will have no safety earth.
Old 2nd December 2009, 02:09 PM   #10
Yeah good point - I'll do that
Presence control on a SE ? vlljpior Tubes / Valves 8 10th October 2005 04:43 PM
presence control vlljpior Tubes / Valves 0 8th July 2005 08:03 PM
Buzzing changes with volume pot position... JoeBob Parts 6 10th August 2004 08:20 PM
Copyright 1999-2017 diyAudio
