| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#71 |
Yeah, I've just refreshed my memory of both spec sheets.
The motors are comparable 11BL vs 12BL. And both appear to be underhung. Major diffs being XMAX, tightness of the suspensions, and moving mass. The parasitic choke isn't as bad as I had quoted either... All the same, my plan above stands reasonably solid. ----------------------------------------------------- You take away one of his BassLites, that corrects for box tuning, but its also gonna cut into efficiency. Hows that gonna compete with the MOW's which are already +5dB louder??? Hoffmans iron law etc etc... ----------------------------------------------------- I agree that separately enclosing the MOWs into a much smaller volume would be a safer bet. But how to do that? Make cups from the bottom of Home Despot buckets??? Last edited by kenpeter; 7th November 2009 at 12:22 AM. |
#72 | |
It'll go deep, but one basslite never gonna be as loud as two MOWs... |
#73 |
Worth a try.
![]() Cheap enough anyway. Taking out one basslite allows for reasonable tuning for that driver, increasing bass production. The MOWs will dominate the sound anyway, whether there are 1 or 2 basslites - they play in the most sensitive range of hearing and they are more efficient. |
#74 |
Or take out the MOWs entirely. One basslite per half,
block off and port the empty holes. Build a new 2x12 box for the MOWs to stick up on top. Prolly even run the MOWs open back, save some weight. |
#75 |
The basslite driver appears to be designed for a 80Hz. punch peak in a box of around 2cu. ft., so two of them in a vented box of about the size you have is just about right.
For a down tuned e string or a five string, a peak at 50-60Hz. is preferable. All you really need is one guitar driver for two of these, (using a series capacitor to keep out the lows), and putting it in an open backed box on top of the other one would seem to be the easiest way of getting what your after. rcw. |
#76 |
well I'm currently taking out the crossovers to see the difference.
#77 |
Ok, with no crossovers and still separated it sounds better. more punch due to the MOWs. the basslites add some rounded bass but are still overpowered by the MOWs. I guess I'll cut some holes through the shelf and see what happens
| Complicated psuedo-scope question | Rob11966 | Tubes / Valves | 12 | 12th September 2009 02:09 AM |
| Tuning a guitar by comparing harmonics on adjacent strings | poptart | Instruments and Amps | 15 | 5th January 2009 06:22 PM |
| 1x10" bass guitar monitor with variable port tuning and notch filter? | alexclaber | Multi-Way | 7 | 1st April 2008 06:24 PM |
| Complicated reflex-loading question | DeonC | Multi-Way | 9 | 8th July 2006 10:58 AM |
| Tuning Question (Sealed) | kiowamec | Multi-Way | 9 | 23rd May 2006 07:47 PM |
