Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 4th November 2009, 05:52 PM   #11
Send a message via AIM to andrewskaterrr Send a message via MSN to andrewskaterrr
ok that's what I thought
I read that acoustic foam helps absorb standing waves, cleaning up the sound, that's why I got it.
Old 4th November 2009, 06:10 PM   #12
Charles's law - Wikipedia, the free encyclopedia
Boyle's law - Wikipedia, the free encyclopedia
The stuffing supposedly soaks up temperature changes.
So you are only fighting one ideal gas law, and not both...
Old 4th November 2009, 06:26 PM   #13
I see what they're talking about.
Well I've done all my calculations, I have a volume of 2ft^3 after I take out speaker displacement, inductor, wood, and foam volume. So I end up needing 2 ports that are 2.75 in dia and 5 in deep.
So now I need to decide if i'm put them in the front or back. I'm afraid that if they're in the back the bass wont be as punchy.
Old 4th November 2009, 07:09 PM   #14
Irrelevant, cause ports don't punch. Cones do.
Your cones is located on the front, yes???
Assuming system is tuned punchy (Q <= 1)...
I mean, you still gotta tune your box not too
mushy for the driver to have punch. But port
placement??? Really nitpicking.
I'd shave an inch off the lower back. And hope
maybe the corner of the wall and floor will give
me a little horn loaded boost.
Keep the cutoff. If you later discover you need
to block off part of the vent. Screw it to the
bottom (on the inside) and abuse to adjust.
Also your circuit might be flipping over phase
around the crossover frequency? I don't know
your crossover circuit, is it more than just a
choke coil?
Tried seeing what happens if you deliberately
miswire woofs out of phase with the MOWs?
Sometimes that fixes phase, sometimes not...
Old 4th November 2009, 11:08 PM   #15
ditch the acoustic foam and the inductor, this is a guitar amp.
If you can't get the sound you need from your AMP controls, this is where the problem lies...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 4th November 2009, 11:53 PM   #16
rcw is offline rcw  Australia
This type of box is a part of a musical instrument and not intended to reproduce sound, look on it as the body and sound hole structure you find in a bass viol.
Bass guitar boxes in general have a 60Hz. punch peak, and you will find the typical bass guitar driver is uptimised for this. In general it is best to design the box for the formant you want, then tweak the tone controls.
Having a steep high pass filter about an octave lower than this is also advisable since bass guitars produce a very large d.c. component that causes a large cone offset, and this can be greatly increased by the technique of damping the strings with the hand.
The effect of this offset is to soak up large amounts of power and produce no more sound.
rcw.
Old 4th November 2009, 11:59 PM   #17
rcw.
the whole idea of the cab was to have a biamped/biwired cab.
Old 5th November 2009, 12:02 AM   #18
So put the ports on the back panel towards the edges? And I'll switch the + & - on the basslites and see if that helps
choke coil?
Old 5th November 2009, 12:34 AM   #19
You could try removing just the cap, running the MOW`s fullrange, then you`ll get more bass.
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
Old 5th November 2009, 03:35 AM   #20
from what I've read, that would give a funky load that the amp would see, you need to have the cap and induc as close to the same frequency as possible
Complicated psuedo-scope question Rob11966 Tubes / Valves 12 12th September 2009 02:09 AM
Tuning a guitar by comparing harmonics on adjacent strings poptart Instruments and Amps 15 5th January 2009 06:22 PM
1x10" bass guitar monitor with variable port tuning and notch filter? alexclaber Multi-Way 7 1st April 2008 06:24 PM
Complicated reflex-loading question DeonC Multi-Way 9 8th July 2006 10:58 AM
Tuning Question (Sealed) kiowamec Multi-Way 9 23rd May 2006 07:47 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
