Sunn Sceptre: Weak Vibrato Cause? - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 24th October 2009, 02:42 AM   #1
slor is offline slor  United States
Default Sunn Sceptre: Weak Vibrato Cause?
Hi there,
I have a 1970 or so Sunn Sceptre. The vibrato was essentially non-existent when I bought it; someone had replaced two of the electrolytics in the vibrato section with the wrong values, so I went in and replaced all the electrolytics for the heck of it (several looked a bit iffy).
Now, I can hear just a "shadow" of the vibrato superimposed over the signal, which is an improvement I suppose but not much of one. I was going to investigate the transistors in the circuit, thinking maybe the 2N2102 isn't putting out sufficient voltage to fire the LDR completely? Just shooting in the dark, really. I would try a different photocell but it's an obscure model. Any tips at all would be appreciated!
Old 24th October 2009, 10:36 AM   #2
m6tt is offline m6tt  United States
Coupla ideas...
Do you need the footswitch to activate? (ala Deluxe Reverb)
Is the bulb good?
Can you replace all of the transistors involved?
Do all the resistors measure spec?
Take the LDR out and measure light and dark resistance?
How does everything measure after (and including) the 1n2070?
Just some guesses. Interesting design, good use of SS when they use it.
The 6AN8 driver circuit is fairly unique!
Old 24th October 2009, 11:50 AM   #3
работник
Rod Coleman's Avatar
I fixed a Gibson vibrato with this kind of circuit.
Quickest way to a fix was:
unwrap the LDR/lamp module so you can see the bulb. power up and set vibrato to SLOW - see if the lamp lights. It only has to be gently lit, with pulsed brightness at the vibrato frequency.
If that's OK, suspect the CDS cell (the receiver section of the LDR). My Gibson went open circuit. I pulled a CDS cell out of one of those joke gnomes that fart when you cast a shadow on it - resistance 1M (dark) & about 40K in some grey English daylight. The farting gnome's CDS worked perfectly, with no adjustment needed.
Old 25th October 2009, 08:45 PM   #4
Thanks Gents,
Yes, the footswitch is operative, it turns off and on the "shadow" vibrato. I'm gonna see if I can puzzle out the transistors and make sure they're delivering what they should;
I'm not sure if I can disassemble the LDR / lamp module, it's pretty burly compared to the plastic-wrapped Fender version. With any luck, I won't have to resort to farting gnome technology!
Fender Twin Reverb VIBRATO PROBLEM - weak vibrato gibsonripper Instruments and Amps 2 19th January 2008 04:23 AM
Schematic for a Sunn alpha 115 gtrtech Instruments and Amps 1 1st February 2006 04:08 AM
help with this Vibrato Circuit nordine Instruments and Amps 16 18th August 2004 05:05 PM
Copyright 1999-2017 diyAudio
