Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 5th October 2009, 07:59 AM   #1
Default Cross over distorition in guitar amp
I have scrambled some parts and built a 50W guitar amp, Marshall style mostly.
I have some problems with cross over distortion that i can't solve, hope some one can help.
Facts: 2xEL34, OPT 3.2K, Anode Voltage 440V(!).
When i bias the tubes to about 45mA (440V * 45mA ~ 20W dissipation) i still get way to much cross over distortion.
Trace of ruffly 26W output power (into a 9.4 ohm resistor, 5V/div):
Trace of ruffly 60W output power (into a 9.4 ohm resistor, 5V/div):
Looking at older schematics and voltage charts for Marshall amps, it seems that my voltages/currents/OPT ratio is not to far off. Is this normal for Marshall amps?
Any advice most welcome!
/Mike
Old 5th October 2009, 04:53 PM   #2
porkchop61's Avatar
Mike-
Are you using a 12AX7 as the PI?
Maybe a not well matched (balanced) 12AX7 could cause this?
[EDIT}]
I forgot bias (cold if I remember right) is the cause for this (It's been a while since I built my Marshallesque-type clone)
To answer your question, this isn't typical for any Marshall amp I've seen. Mine does
not have this issue.
Glenn
"Imagination is more important than knowledge"
Old 5th October 2009, 06:07 PM   #3
Originally Posted by porkchop61 View Post
Mike-
[EDIT}]
Glenn
Thanks for your reply. Yes it is a standard long tail PI with 12AX7, taken from a Marshall 50W schematic. It looks close to perfect on my scope, so i don't suspect the PI.
I know from other tube amps that i built that correct bias removes the cross over distortion. I just can't do that with this amp, as i'll run it too hot if i do. I suspect poor impedance matching (i.e. load line), but then wonders how it could work in the standard Marshall amps?
/Mike
Old 5th October 2009, 07:16 PM   #4
porkchop61's Avatar
Is your OT similar to the Marshall in specifications?
I run my EL34's at around 19W plate dissipation, but I'm kind of conservative.
Old 5th October 2009, 08:17 PM   #5
mjf is offline mjf  Austria
hello.
this kind of distortion can be caused by magnetic saturation of the opt.
lower output power should show less distortion.......some guitar amp designs use this to create a special sound.
if you do not want it you can try out a bigger opt.........
greetings........
Old 5th October 2009, 08:31 PM   #6
The tranny is "Sovtek JMP 50-2" (anyone heard about that before?). I meassured the ratio, and it is 3.2K, as should be for Marshall.
Originally Posted by mjf View Post
hello.
greetings........
If you look at the pictures above, you see that the dist is clearly present at only 26W output, and i could see it as low as 10W. If it indeed is magnetic saturation, could it be visible at such low power? As for the physical size/weight, it appears to be a typical 50W tranny.
The only thing i see out of spec is the plate voltage, that should be around 380V according to Marshall specs, while mine is around 440V. Could that be the reason (though it's such a small miss match)?
Old 5th October 2009, 09:35 PM   #7
Michael Koster's Avatar
Is the bias voltage changing with applied signal?
What does it sound like when you play through it at various volume levels?
How do you calculate power? Using Vrms^2/Rload I get:
Trace1 => 24VP-P = 8.5VRMS => ~7.6W into 9.4 ohms
Trace2 => 34VP-P = 12VRMS => ~15W into 9.4 ohms
Michael
Old 6th October 2009, 06:19 AM   #8
Miles Prower's Avatar
There's your problem right there. A 3K2 PP OPT works out to 800R / phase, and gives you a nearly vertical loadline. You're operating them almost Class B, so all that x-over doesn't come as any big surprise. The spec sheet for the EL34 doesn't call for a plate load anywhere close to 800R / phase.
800R / phase would be more suited to one of the TV HD finals, like a 6JN6, or a 6DC6.
Given that load, I'm surprised you haven't sent them to Red Plate Heaven.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 6th October 2009, 06:41 AM   #9
revintage's Avatar
It actually does! 3,4kohm(850 Class B)/400V as presented by Philips is not far away.
But as above, rising Ua an lowering Raa is going in absolutely wrong direction
Brgds
Lars
Old 6th October 2009, 08:09 AM   #10
That brings us right back to the original problem, doesn't it? Class B means x-over distortion. That's why it's best reserved for RF amps, where distortion of RF cycles is filtered out by LC tuners and/or BPFs.
Audio Class B is OK for lotsawatts for AM plate modulators or PA systems where you don't care about fidelity. Otherwise, sonically, it just plain SUX.
www.dolphin-hsl.com
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
Cross over help guru_jeff Multi-Way 21 3rd October 2006 01:59 AM
How to cross over Learnincurve Subwoofers 7 30th January 2005 06:42 PM
How do you cross over really low? Nappylady Multi-Way 7 25th June 2004 08:29 PM
What do you get when you cross... nobody special Pass Labs 13 12th October 2002 05:47 PM
Page generated in 0.12462 seconds (78.70% PHP - 21.30% MySQL) with 11 queries
