Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd October 2009, 03:34 PM   #1
MellowTone's Avatar
Default Tube overdrive for guitar/bass
Hey guys,
I'm looking to build a quick tube overdrive/distortion for instruments (primarily bass guitar). I've looked around on the internet and these forums and haven't been able to to find anything as far as a proper schematic goes. I will use a 12AX7 tube for it. I need a schematic and the specs for a transformer and I'll go from there. What sort of B+ would get what I want? The only control I plan to give it is a gain control, going from very little overdrive, to completely nuts. Any input is greatly appreciated.
Nic.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 3rd October 2009, 04:50 PM   #2
HollowState's Avatar
Maybe you'll find something here:
http://www.freeinfosociety.com/media...at=11&start=0#
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 3rd October 2009, 05:04 PM   #3
I'm afraid there are a few contradictions here ;-) ; finding the really right circuit that works for your tastes might take a while of trying, changing etc.
Don't necessarily say it needs to be tubed either, after having used a (starved tube) pedal for years, I'm now again back to a fairly simple but modified tubescreamer-based circuit. Or maybe you've already 'done the work' & know you'll be liking tube-based the best.
If you want distortion from tubes you need to decide if you want to go the 'cheap'/easier starved-plate route (lower B+) or the 'real' one with higher (normal) tube voltages.
Suggesting at least a second control: level. Some EQ will suit as well imho. A tried & tested (but not necessarily the best solving your needs) is the Real Tube pedal, that circuit should be around the interweb.
Bye,
Peter
Old 3rd October 2009, 08:00 PM   #4
richwalters's Avatar
Originally Posted by clintrubber View Post
I'm afraid there are a few contradictions here ;-) ; finding the really right If you want distortion from tubes you need to decide if you want to go the 'cheap'/easier starved-plate route (lower B+) or the 'real' one with higher (normal) tube voltages.
Bye,
Peter
We all have different tastes. A trip down to the music store to compare often against $$$.. I prefer a variable B+ only on a P-P stage, and fixed bias neg compensated to draw a reasonable stage current. A double pot and some control circuitry can do this. Power is good with a fairly hardish raucous sound. Can be tricky,the global nfb loop can cause strange sounds, so I drop this around 6-10dB.
There are other methods; hard clipping the grids of finals with diodes as if class B is used; this again with dropped B+. This sounds more solid state..again different amps create different sounds..Ones own choice and other guitar users have other ideas.
All these involve experience of live circuit fudging and the expected sound, not recommended for those new to high voltages in tube amps.
By doing this when playing trumpet, one gets a richer mute sound. I prefer the proper method of a mute corked in the horn of the instrument.
richy
Old 4th October 2009, 10:03 AM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
For bass guitar think of compressor, instead of distortions.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
DIY : SWR Interstellar OverDrive (bass preamp) miguel567_98 Tubes / Valves 13 15th February 2007 07:55 AM
Guitar Amps, Overdrive Pedals, and Space Charged Tubes Turbo7MN Tubes / Valves 14 13th November 2006 11:38 PM
Who sells a tube bass guitar amp kit?? Jack Crow Tubes / Valves 4 23rd December 2005 03:02 PM
bass guitar amp hybrid Tube/mosfet ?? partyjups Instruments and Amps 1 19th April 2004 01:08 PM
Bass Guitar Tube Amp Charles BL Tubes / Valves 17 11th December 2002 11:14 PM
Page generated in 0.54933 seconds (5.55% PHP - 94.45% MySQL) with 10 queries
