Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th November 2009, 02:48 PM   #31
Originally Posted by MJL21193 View Post
Hi Nigel,
I could probably appreciate the simplicity but it's not something I want to get into, I feel no attraction to tubes at all and I believe it can be done just as well with solid state.
As do I - I come from the valve era, so aren't impressed by their high distortion, high noise levels, and poor frequency response.
Nigel Goodwin
Old 30th November 2009, 02:53 AM   #32
I can respect a well designed solid state amp cause they can sound okay if well designed and built but you gotta be shittin me tube amps take solid state to town in many ways including tone volume prescence etc but thats really great your making an amp i know i couldnt
Old 1st December 2009, 12:51 AM   #33
Send a message via AIM to Spasticteapot
Do you have any samples? Quite a lot of the "guitar amp sound" is derived from pushing power output tubes into clipping, and I've yet to find a solid state amp I really liked that didn't have the benefit of a lot of DSP.
Old 1st December 2009, 01:56 AM   #34
MJL21193's Avatar
Some good reading here from a guy who knows a thing or two about the issue (Warning: file is large).
I didn't want to make this a tubes vs solid state thread - as I've said, I have zero interest in that archaic method of amplification and I am not charmed by its warm glow.
Old 1st December 2009, 05:47 PM   #35
gain-wire's Avatar
I respect your desire to not turn this into a tubes vs transistors thread, but let me add this (it's in transistor's favor anyway, even though I love both):
I own two traynor amplifiers: a DG30D and a YCV20.
The DG30D, as some of you may have guessed is a solid-state combo amp (12 inch Celestion) with digital effects and including reverb. I was not impressed by this before I listened to the amplifier. I must admit it has one of the best reverbs I've ever heard, including my yamaha FX-500 effects processor.
The distortion is good if kept under 8, and the Vibrato, Flanger and Chorus all sound decent even though you can't adjust anything.
I love this amplifier.
The YCV20 is obviously the tube amplifier, and it breaks up into nice crunchy distortion when I want it to, then cleans up. The spring reverb is thin and actually it feeds back if set past 5! Overall I really like this amplifier, the distortion channel's tone is nice if kept under 5 then it gets "flabby" distortion. The clean if pushed to the maximum sounds better, according to me.
I also love this amplifier.
It is true that tube amplifiers (including the YCV20) are VERY Dynamic, and that's what I like. BUT it depends on the type of music you play, if you don't need to be dynamic in your playing, switching from clean to overdriven tones, then a tube amp is useless.
It really depends on what type of sound you're trying to achieve, and that depends on what type of music you like to listen.
If you like KISS, Judas Priest, Metallica, etc, a solid-state amp will never give you the overdriven sounds like them.
But clean tones? Solid-state rules. In efficiency, weight (transformers) and harmonic distortion.
All I'm saying is that it depends what you want to hear (and feel).
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 20th December 2009, 07:56 AM   #36
mondogenerator's Avatar
for home MUSIC REPRODUCTION i would have to agree---though in my experience with many SS amps, no 'IC based overdrive' or simulated valve sound is worth poop. yes valves CAN be noiser, but the overdirve and clean sounds take SS to the garbage tip. UNLESS youre a bass player and have a 1000W rig and 4x10+2x18 so you dont sound like a bee in a bean can at 115dB
and to the OP...eminence ARENT bad speakers...but they arent celestion green backs either---i would go for the latter in a SS amp IMHO
Old 30th January 2010, 09:08 AM   #37
Wow..nice cab
Have you had a look at the Weber alnico budget range speakers?
I gotta get four 10" Weber's for my Fender Super Reverb
they're $40 each, THE 12'S might be slightly more
I love valve amps, but tranny amps can sound pretty good
I've got an old Pignose 30/60, it sounds great and can just about
keep up with a drumkit at a jam
I don't have the circuit, but they're worth a look for a valvey-sounding SS
Cheers, Max
Old 7th September 2010, 04:23 PM   #38
Nice Thread!
Old 30th September 2010, 05:27 AM   #39
Default being pedantic but....
maybe a valve front end, single or double channel; and a good solid SS output end would be a good alrounder......some SS amps DO sound gorgeous on clean sounds, if a little 'cool'.
either way...great looking cab (my fave colour!)
what speakers did you/will you use?
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes...
Old 10th October 2010, 09:45 AM   #40
chris661's Avatar
I don't know how interested you are, but...
CELESTION|G10 GREENBACK 8 OHM|LOUDSPEAKER, GUITAR 10" 25W 8R | CPC
£55 for a 10" greenback.
Looking forward to seeing this finally up and running,
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
A guitar (and more) amp for my son akis Instruments and Amps 3 9th July 2009 08:52 AM
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
Guitar help please! iNOS_dragRacer Instruments and Amps 16 12th May 2006 08:51 AM
6V6 Guitar Amp SHiFTY Tubes / Valves 2 5th August 2003 02:10 PM
Page generated in 0.11891 seconds (78.21% PHP - 21.79% MySQL) with 11 queries
