| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#131 |
Aye, you could probably make a fair amount of money making and selling guitar amps.
They do sound good. Very good. How much do you charge? If you wanted to mess with the distortion, I'm told changing the diodes in the feedback loop will change the sound drastically. Try more than one diode in series and you can get asymmetrical clipping, which gives an interesting sound. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#132 |
Thanks Chris!
No plans to go commercial (that would ruin the fun, no doubt) and the smaller one is gone - to it's new owner. Parting with it was hard... I don't know if you saw it, but HERE I designed the preamp for 'The Steamer' and I must say that I'm VERY pleased with the results. I'm so pleased, that I'm going to redo (again!!!) both channels in this amp to this new configuration. The distorted channel will get some extra attention, but the clean will be the Steamer preamp without changes. |
#133 |
Just watched it. Your friend has a beautiful 335. The amp turned out great. Now =how about a tube amp ?
#134 |
My friend thanks you
No plans (ever) to build a tube amp but I have something else I've been toying with that involves a high voltage (200V+) output stage and an output transformer. I think that some of the 'magic' attributed to tube amps is imparted by the output transformer. Also, tough to clip an output stage that has that kind of voltage swing. I haven't decided if it will be single ended or push-pull. |
#135 |
John, it'd be easy enough to rig up a 1:1 transformer, using something with suitably rated dual secondaries. I found each transformer sounds different, but it'll probably give you an idea of what they do to the sound.
200v is a lot, though. I should know...
#136 |
It is a high voltage/low current idea that I may or may not try. I don't think I'd bother putting a transformer on the output of a regular power amp.
| A guitar (and more) amp for my son | akis | Instruments and Amps | 3 | 9th July 2009 08:52 AM |
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| Guitar help please! | iNOS_dragRacer | Instruments and Amps | 16 | 12th May 2006 08:51 AM |
| 6V6 Guitar Amp | SHiFTY | Tubes / Valves | 2 | 5th August 2003 02:10 PM |
| Page generated in 0.07833 seconds (76.46% PHP - 23.54% MySQL) with 11 queries |
