Yet another Guitar amp project - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th September 2009, 11:06 PM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Please consider to move this thread to "musical instruments" thread
Will be easier to find
And it might be on front page for much longer
If the ESP preamp is good, maybe this new "41hz" classD could be used
http://www.41hz.com/shop/item.asp?itemid=45
But now I may be like the "newbies" who ask, "hey, I want to build a super highend speaker, how do I choose drivers"
Eh, sounds like the "41hz" amp7 might be used, but the ESP preamp not, hmm
Old 28th September 2009, 10:05 AM   #22
akis is offline akis  United Kingdom
Originally Posted by Minion View Post
The Face Plate is Aluminum , it is 6 in x 19 in , so the Box is going to be 17 wide 12 deep and 6 high , the metal shop were I live quoted me $30 for the Stainless steel sides and Top , gonna use a steel bottom and aluminum back to affix the heatsinks ....
Cheers
So you are using an inverted U-shape as the side-top-side of the enclosure with a separate bottom and a separate back? How are you going to put all this together? And why not use aluminium bottom so it is easier to drill into and mount components? Or are you going to have a false aluminium bottom?
Old 28th September 2009, 10:08 AM   #23
Originally Posted by MJL21193 View Post
Thanks again
That is my homemade circle cutting jig:
Attachment 142207
The plywood is cheap 3/4 inch sheathing. I ran it through my thickness planer then lots of sanding to make it smooth.
Ah I think I see, you drill a pilot hole at the middle and then attach the jig with its screw and secure with the butterfly nut.
I used jigsaw for everything. I also have a table saw and a chop-saw, but never the less I used the jigsaw for 90% of cuts. And it does not come out good when you use the jigsaw.
Old 28th September 2009, 12:59 PM   #24
MJL21193's Avatar
The jig has a 1/8" pivot pin (circled in red in photo).
I just drill a 1/8" hole in the centre, put the jig in place and set the diameter using the scale on the jig. Very fast and convenient.
Nothing wrong with using the jigsaw, just this is faster and more accurate - no laying out the circle before the cut.
I have changed my mind on the preamp and I'm now going with a discrete design. See here for details.
Old 28th September 2009, 11:38 PM   #25
Minion is offline Minion  Canada
Hi , yes , gonna have a U shaped Top and Sides and I am going to join the Top/sides , front ,back and Bottom with small L Brackets , I got these ones that are threaded and come with little bolts that fit them .......
I was going to use a Steel bottom because it is a Lot cheaper ($5 compared to $15 for Aluminum) and I used a steel faceplate before and I didn"t have much problem drilling through it but I might still splurge for aluminum depending on my cash flow at the time , hell I might even use a wodden bottom as it would make it easier to affix everything together ...... I"ll probably make sure everything or at least the preamps and equalizer work before I get the rest of the enclosure it will probably be month before it is finnished as time is a comodity I don"t have much off......
Cheers
Our Guitar Amp Project PB2 Instruments and Amps 38 7th May 2011 12:44 AM
wireless guitar project Optical Instruments and Amps 14 28th December 2010 05:11 AM
building guitar amp... first project! help ashade Chip Amps 22 28th October 2006 02:05 AM
Guitar Amp Project amperex Instruments and Amps 4 10th February 2006 07:56 PM
Copyright 1999-2017 diyAudio
