Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 30th September 2009, 05:11 PM   #11
Key is offline Key  United States
Originally Posted by mondogenerator View Post
yes HUMBUCKERS ARE wired in SERIES as jed says...but you could also wire 2 single coils together in parallel to make a humcanceller...cancels hum in the same wasy as humbuckers but also has a cleaner more single coil tone if thats what you like...also if theyre tapped and switched via a pull out pot you can change the configuration at will
My strat seems to be like this. If I am in a single pickup position I will usually get some interference. But they sound like they are wired out of phase from each other because on any position where you use 2 pickups the noise is cancelled out.
Old 30th September 2009, 08:06 PM   #12
This is normal. The middle pickup is probably reversed both magnetically and electrically so you get hum cancelling when using the middle pickup with one of the other two.
Note to myself: Never again use fingers to check if there still is voltage left in a capacitor...
Old 1st October 2009, 06:33 AM   #13
Yes, that is actually the case. This is also done with some Fender basses for instance. If you use both pickups you have mum cancelling if you use one there is some hum. Marcus Miller once said in an interview that he always uses both when there should be silence (i.e. between songs).
Charles
pick-up's motor cc guyzard Everything Else 12 9th May 2009 12:59 AM
Help me pick a DAC kuroguy Digital Source 5 28th January 2008 08:40 PM
Which cap would you pick? davidallancole Parts 11 7th December 2007 02:51 AM
Page generated in 0.07179 seconds (75.30% PHP - 24.70% MySQL) with 10 queries
