| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 | |
Psssst..... try a parametric mid EQ I designed for CK Amps ![]() http://www.ckamps.com/ToneGeeks/Tone....msg166#msg166 |
#12 |
Of course, once you finish the amplifier, you can start immediately on the effects boxes. You can find designs at:
http://www.diystompboxes.com/pedals/schematics.html and there are others available with pre-etched circuit boards at: http://www.tonepad.com/ I have a couple of old PA amplifiers that I am converting to guitar duty. I had to travel about 100 miles to get them which is how I came up with my screen name. |
#13 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#14 |
Me too! |
#15 |
Thanks for the comments,
I am having fun building this. I hear the comments about MDF vs ply, but unfortunately, I have already completed most of the construction of the cabinet. I don't feel like re-building it at this stage, as progress is slow based on the every second weekend requirement to do it with my son. Perhaps an ooption might be to 'upgrade the cabinet' with him as a future project. At this stage we have decided against a tolex covering, opting to go for a painted dark charcoal grey hamertone finish. Driver will be covered by a black metal mesh grille. Have mixed the colours of the chicken head knobs up for interest. Gain - blue, tone - red, presence - white, volume - black. Have some chromed corner protectors, so I hope we get a 'retro cool' look. I am not sure if it is a 'Marshal' or a 'Fender' sound. I will paste the links below to the schematics I used. I am guessing about two hours of wiring up will have it to the point where we can plug his guitar in to test. AX84 lead preamp AX84 20W PP poweramp |
#16 | ||
Thanks on the EQ comments, guys!
![]() Quote:
![]() I hope you post pics. Quote:
Cheers! |
#17 |
Hi Chris,
You mentioned a while ago that you were building this. It looks great. Another fantastic job. Where did you get the chassis? Look forward to seeing the finished product. Good luck. Rob |
#18 |
Yes, more Marshall than Fender. The 470pF cap and two .022uF caps in the tone stack will give a more Marshall-like slope to the filters. (Fender uses 250pF, .1uF and .047uF in those places.) The cathode-follower is also a Marshall feature, absent in the blackface Fender preamp.
It'll be cool, I know that! -- |
#19 | |
http://www.schematicheaven.com/fende...luxe_aa763.pdf http://www.schematicheaven.com/marsh..._50w_2204u.pdf An Australian discussion board you may find interesting for its local content: http://www.guitargear.net.au/discussion/index.php There is an "In The Shed" area of the forum, where guitar amplifier builders can discuss their projects. |
#20 |
Thanks for the interest!
Yes, definitely photos to follow with progress. The chassis is just a standard Hammond. I have primed it with an etch prime (straight from a spray can) and then coated with a burnished aluminium spray (from a can also). I labelled with decals, just like those model aeroplane kits you built as a kid . Decals were made from some decal paper that goes in to your laser printer. It works pretty well. After applying decals I gave a couple of coats of clear. Looks a little nicer than the raw aluminium and does not scratch as easy.Cheers, Chris |
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| JLH Guitar Amp | lcsegeng | Solid State | 1 | 14th March 2007 07:12 AM |
| DIY guitar | BassAwdyO | Instruments and Amps | 41 | 8th January 2006 06:32 PM |
| Guitar to DIY amp? | silentblackhat | Instruments and Amps | 2 | 27th July 2004 06:36 PM |
| 6V6 Guitar Amp | SHiFTY | Tubes / Valves | 2 | 5th August 2003 02:10 PM |
