diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   behringer powered mixer - must force clipping w/ pad off in order to run normally???? (http://www.diyaudio.com/forums/instruments-and-amps/147474-behringer-powered-mixer-force-clipping-pad-run-normally.html)
zappacrappa 14th July 2009 02:50 PM
I have a Behringer PMH880S 10-Channel Powered Mixer with FX (800 Watts). Its only a year old. All of a sudden I notice my left channel doesn't work, but I can still kind of hear scratchy sound coming through. So I force it to clip, and then its normal; perfect regular sound coming through like the right channel. Why do I have to have a loud sound (clip) to make the left channel work. I only have to force it to clip when I first turn on the amp. Even after I turn the amp off, if I use it within the next 10 minutes, the left channel still works fine. If I leave it for more then say 20min, I have to re-clip the left channel by making a loud sound in the microphone to make it work again.
EchoWars 14th July 2009 07:23 PM
Intermittent / bad solder connection, or a flaky semiconductor somewhere that needs to be beaten into submission before it decides to work.
The possibilities are endless...
Wavebourn 14th July 2009 07:37 PM
It is definitely bad contact somewhere. You need to open it and go through it with a scope.
Enzo 15th July 2009 04:01 AM
Find the power amp in jacks for that channel, squirt in some cleaner, and work a plug in an out several times. See if that helps.
It really sounds like a cutout contact on a switching jack somewhere.
Failing that, squirt some cleaner in hte power amp assign switch and the speaker processing switch and slide them bac and forth a forth a few times.
It doesn;t really sound like a bad electronic component.
Resources saved on this page: MySQL 18.75%
