| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
One needs to realize that if you use Speakon to 1/4 inch plug cables that the "A" channel 1/4 inch sleeve is the HOT speaker signal to system ground.
DO NOT allow this to be shorted to ground. If one tries to use a DI from speaker output without ground lift you will blow the A side amp. The A channel is inverted in the mixer and the A output is again inverted at the output resulting in the sleeve being the HOT speaker lead. They do this to implement the bridged mode easily. |
#12 |
Thanks Fredy2.
The power amp stopped working completely. T4 was shorted, so I replaced all 4 IRF9460 and 640's fets, R1, R8 were open, and D9 15v Zener smt was also open along with R50 smt. On initial test, I was getting 51v at the speaker out on left output, but the fault was a cracked trace at D5. With all those in, it fired up lovely. The speakers are 8ohm 150w cabs Thank you for your reply.. Regards. Saranden |
| looking for pmh3000 behringer power mixer schematics | alexclaire | Class D | 100 | 22nd May 2012 03:43 AM |
| Need Behringer PMX-2000 Schematics | Zero Cool | Instruments and Amps | 3 | 14th October 2008 01:40 PM |
| Behringer Denoiser SNR2000 schematics? | Carlos3350 | Analog Line Level | 0 | 8th March 2007 07:37 PM |
| Page generated in 0.06026 seconds (68.87% PHP - 31.13% MySQL) with 10 queries |
