bass speaker help - Page 52 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st November 2012, 06:20 PM   #511
Depending on how high the basshorn has to go you could use a bandpass horn like the old turbosound ones were.
Charles
Old 22nd November 2012, 07:56 PM   #512
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by phase_accurate View Post
Depending on how high the basshorn has to go .....
100hz to 2khz would be ok not sure folded is so good
anyway, I removed the tweeter series inductor
sounds better without it
it dealt with some electronic issue I had with effect units
and those were removed a while ago
the only effect box I use now is a compressor
and only because it gives a little exstra gain I need
Old 26th November 2012, 10:51 AM   #513
Up to 2 kHz would be fa too high. Even the 800 Hz that EV used for the old "Eliminator" Basshorns for instance was too much IMO. Let alone for a bandpass horn.
Charles
Old 26th November 2012, 11:13 AM   #514
folded bass horn is way too big for the standard famely car anyway
my own next project is planned to be more 'lightweight'
I almost have the sound I like now
its just too heavy for easy transport
so now the challenge is to achieve the same, just in a smaller package
Old 14th December 2012, 12:02 AM   #515
this must be the weirdest idea I have had yet
Old 15th December 2012, 03:37 PM   #516
looks like it will be built
Old 16th December 2012, 03:44 PM   #517
small update
Old 17th December 2012, 03:14 PM   #518
This is a quite elegant looking solution but I fear that it doesn't differ that much acoustically from the other horn/reflex hybrids that are around. But it might be a little more complicated to build compared to the latter.
Do you know the cube shaped front-loaded horn from "Klinger". It is quite compact with a side-length of 60 cm. But you would of course need a high-efficiency midrange that goes quite low.
Charles
Old 17th December 2012, 03:36 PM   #519
it is midhorn with apperiodic backchamber, not reflex...thats the difference
and I wont risk loosing it because of a too high port tuning
anyway, I bought the plywood today
I need to test it before I build more
2 or 4 would be cool
Old 17th December 2012, 08:03 PM   #520
ahh, since I know it will be the best bass guitar speaker this world have ever seen, why not just build both channels right away ....and thats what I have decided to do
looks like I will need one more 12"
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 04:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 09:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 05:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Copyright 1999-2017 diyAudio
