bass speaker help - Page 47 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 24th May 2012, 12:14 PM   #461
Originally Posted by lduarte1973 View Post
you might be right about that , but id still try it with a tube pre you might prefer its tone
Why would you want to lower it's quality?.
I can see the reasoning for guitar, where distortion is often preferred, but bass is more often clean and high quality.
This is why the vast majority of bass amps are solid state, and not valve.
Nigel Goodwin
Old 24th May 2012, 01:12 PM   #462
Sin Bin
well i guess mine is an exception then , it has tubes and a clean sound
Old 24th May 2012, 03:46 PM   #463
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
probably more complicated than that, or less
for one, you need gain
and drive power
various effects obviously takes a minimum of power to handle
regarding output stage
maybe the output trafo does something good with its high output impedance
Old 24th May 2012, 04:03 PM   #464
chris661's Avatar
You can get clean out of a valve.
Keep it running in a linear region, add some feedback around it to compensate, and there's no reason it shouldn't sound solid state.
There's a lot of cheaper guitar amps around that use a valve for marketting purposes. Its a simple cathode follower arrangement (often a 12AX7 or equivalent), and the overdrive sound is provided by some LEDs in the feedback loop of an op-amp. Lovely... NOT.
I'm working on a project to get the saturated-valve-output-stage sound from as small a box as possible, and will start a thread when I've got something to show for it.
Chris
Old 24th May 2012, 04:46 PM   #465
Sin Bin
this is my amp tubework 3300RT , not me on the video
Tube Works RT-3300 - YouTube
Old 24th May 2012, 07:38 PM   #466
You 'can' get clean, but what would be the point? - it wouldn't sound any different to a transistor amp (but would be massively larger, heavier, more expensive, and under powered).
This is why most bass amps are transistor.
Nigel Goodwin
Old 24th May 2012, 09:52 PM   #467
hey, its cheating, thats not a tube amp but much better, its a mosfet SS solid state
Old 4th June 2012, 04:13 PM   #468
Sin Bin
it has a switch so you can choose tube or fet for preamp stage , i believe the tube is a 12ax7
Old 5th June 2012, 10:53 AM   #469
Sin Bin
mine is a hybrid 300w
Old 5th June 2012, 04:16 PM   #470
is the driver stage tube or SS ?
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 04:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 09:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 05:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Copyright 1999-2017 diyAudio
