| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#412 | |
It may be that the bass guitar has almost no tweeter content. Or switch off the bass and mid speakers and listen to the tweeter alone (don't adjust the volume). That should show what the treble content is and why you "hear" that effect. |
#413 |
not much I guess
even so, tweeter phase is still affecting other drivers in the system ![]() but you know that strange and worse things might happen when 'something' rolls off rapidly tells us about it, please ![]() btw, I have tried a big light coned woofer and just hated its squeaky midrange I suspect caused by a too big, stiff and light cone well, muffled aint too good either its not so easy at all hey, I love my new speaker, no doubt about it and my bass is vey cheap, and a better one ought to give better sound right now I fancy a 5-string Steinberger
#414 |
ahh, found I had a bigger inductor, amd changed the paralel curcuit on tweeter
WOW, the whole speaker sings nicely now well, it is a big surprice it actually works that way, and not much differnet from a hifi speaker proves my worst fears will post xo schematic later |
#415 |
crossover, but still preliminary
not looking perfect at all, but it works because I have made multiple changes and adjustments, and all resulting in improved precison and playability, I would say it is getting quite good now but I need to buy more components to any further still surprising how much a tweeter xo affects the playing |
#416 |
shoot, paralel inductors were shown/drawn with wrong connection
corrected, and a bit different ![]() btw, I shot a few new and better pics of my project I think you can take it just once more ![]() Im beginning to enjoy it, and it more and more every day got nice tune, and rocks, its good
#417 |
crossover change/update
less noise/hiss and now the 'onboard' tone control pot on bass guitar actually works makes the sound more airy, instead of just 'nasty' and even better tune, improving playability further compressor pedal arrives in a few days will be interesting what that will do |
#418 |
#419 |
I compressor will help if your playing seems to be inconsistent.
I once recorded a bass player where his playing was right on but the levels of him hitting the strings were all over the place. I had to ride that channel a lot during the mix down so adding a compressor fixed most of it. This is the very reason why some bass amps have compressors built in to their preamp. Nice Job on that Speaker, tinitus !!! jer
#420 |
very nice of you, thanks
I have now tested it with hifi music better than expected, given the poor xo but not much to write about either but the tweeter is the really big surprice and indicates that my tweeter xo might work sounds very 'hifi', and clearly points the direction for my future home hifi the next positive surprice was woofer lower midrange but also clear that the early bass rolloff result in wimpy 'cardboardbox' bass only way I can describe the effect even so, for bass guitar it still produce very good and low bass at times maybe even too much just one of those weird things I guess as for the rest...well have to work on upper midrange(bigger inductor) |
| Which pa speaker is the best for deep bass | Bull | PA Systems | 8 | 11th December 2010 04:35 AM |
| AQA*Bass Box + SUB speaker ? | Krokotam_ | Subwoofers | 0 | 27th October 2008 09:20 AM |
| Enclosure for a mid-bass speaker? | neur0tic | Multi-Way | 3 | 2nd September 2007 05:06 PM |
| 15" speaker for a bass cabinet | Zaireeka | Instruments and Amps | 0 | 29th August 2004 02:11 PM |
| bass speaker design help | dbaudio | Multi-Way | 0 | 12th September 2003 12:17 PM |
