Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st July 2009, 09:58 PM   #21
tinitus is offline tinitus  Europe
Funny thing
But only needing one, this impressive 15" is affordable
Impressive 16mm Xmax(p-p)
And deep bass is possible with 31hz Fs
And its a low distortion motor design, and huge magnet, which means tight controlled deep bass notes
Its a genuine tough pro woofer, one of the best
http://www.precision-devices.com/showdetails.asp?id=14
Well, it is a sub driver(pro), recommended no higher than 450hz
Probably wont do voices too good
But question is, what does it matter with bass guitar?
Ofcourse it will need some support higher up
A cheap mid/tweeter horn
Or a small 6-8" with good topend
I have those 4 Foster super tweeter, which could be added high up
Old 22nd July 2009, 11:14 PM   #22
Originally posted by Nordskov
Where are you in Denmark, I'm in Odense.
Don't you play in a band?
I might be of better use in a band if I bought a sax
You will get an invite
Im working hard on finding a good affordable 6-string bass
Woofer have changed, again
http://www.precision-devices.com/showdetails.asp?id=5
Old 3rd August 2009, 06:38 PM   #23
Hey, I think I will buy a Carvin 4string Bass-Kit (passive)
But woofer is more or less settled
Winter project
Old 4th August 2009, 06:23 AM   #24
Last weekend I was in Stockholm and wanted to try one of these:
www.woodoguitars.se
Unfortunately the dealer in Stockholm only had a fretless B6 left (six strings AND fretless is like fighting two battles at once I think) and the owner of Woodo (who is a nice guy BTW) was in Finland during this time.
Another affordable one I was looking at is the Cort Artisan A6. It is a little more expensive than the Woodo but it has two trussrods (Woodo only uses two of them for the seven string versions) and Bartolini electronics.
Regarding low bass out of 10" there are two things:
1.) Yes, some 4x10" user a rather large box and low tuning but this is still detrimental to efficiency at the lower end. Most of these cabs do sacrifice low-end response for better efficiency above (it has to be portable, affordable and loud after all).
2.) These 10" drivers do not necessarily have to be stock
PA midrange drivers. If you order dozens or more you can have drivers manufactured to your specs.
Personally I don't like the sound of most bass rigs that much. I think a live gig is recognised from far away as being live because the bass usually sounds crap. IMO bass for grown-ups is not felt in the chest but in the bowles and makes your trousers flap.
I recently went to a gig of S.M.V. and the sound was excellent but I assume because DI was used.
Charles
Old 12th August 2009, 05:11 AM   #25
tsmith1315's Avatar
tinitus:
Well, maybe not affordable, but Kudela will build whatever you want:
Tim
Old 12th August 2009, 09:56 AM   #26
Nice bass mate ! There will be even more manufacturers that will build to your specs. But as you mentioned: It is a question of money !
http://www.alembic.com/
Charles
Old 12th August 2009, 11:55 AM   #27
unclejed613's Avatar
i'd like to find an old aluminum neck Travis Bean. i remember trying one out in the music store...... long time ago.........
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 12th August 2009, 01:36 PM   #28
I own an old aluminium neck Kramer DMZ 6000 B.
http://www.vintageguitars.org.uk/adDetails/328
Charles
Old 11th September 2009, 01:12 AM   #29
Woofer will now be the 12" Beyma SM212 12", with a tweeter/horn
Enjoy this
http://www.morch-guitars.dk/bass_gal...html?linkid=17
Old 11th September 2009, 10:41 AM   #30
Hi Tinitus
A little OT but have you tried out the ESP shown a few posts ago ? It seems to have a newer brother with neck-through construction. Price-diffrerence is around 200 euros.
Charles
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 04:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 09:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 05:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Page generated in 0.09221 seconds (80.98% PHP - 19.02% MySQL) with 11 queries
