bass speaker help - Page 11 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 10th December 2010, 08:49 PM   #101
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by phase_accurate View Post
As most bass players want a clean sound it is important not to use the overdrive section of the amp.
Charles
Im not just thought it was fun
will try to see if I can get a look inside amp
but I doubt its even close 15watt
or maybe its not fit fore passive pickup
Old 16th December 2010, 05:03 PM   #102
chris661's Avatar
A compressor would probably be in order, so that the peaky output of a bass guitar won't destroy speakers.
But yeah, building a cabinet and some sort of amplifier would help things a lot.
My work: www.grimshawaudio.com
Old 18th December 2010, 04:38 AM   #103
bigbeck is offline bigbeck  United States
Another thing: Does the power-amp stage have an output capacitor ?
Charles
Would a bad output cap cause the amp to fart out when you dig in?
I'm playing bass through a 65 watt Peavey guitar amp (clean channel). I'm using the emminence Basslite 2012 (150 watt) in a home made cab built to Emience specs. It sounds good until I crank it up loud enough to play with drums. Then it distorts and sounds farty - almost like it's blown. Any ideas? I did notice a couple of large caps in the output section. Could they be the problem?
Don
Old 18th December 2010, 11:21 AM   #104
chris661's Avatar
I'd suspect the driver's bottoming out.
Watch the driver as you play. If it starts moving a lot (I mean more than 10mm p/p), you need more drivers, or a driver capable of moving further in a linear fashion.
Apart from that, the amplifier may be clipping.
As a comparison, I use 1x10" and 1x12" in seperate cabs for guitar use, to keep up with drums. With around 80w into them (~40w each). They keep up, but there's not much headroom.
1x12" to go down to 41Hz (bottom E) at drum levels doesn't seem enough.
I can't find detailed cabinet specs for that driver, what did you tune the reflex port to?
Chris
Old 18th December 2010, 06:41 PM   #105
I built the larger cab 2.7 cubic feet. Here's the data sheets for Basslite S2012
Don
Eminence - The Art and Science of Sound
Old 18th December 2010, 07:04 PM   #106
No, you'd just get a lack of bass.
As suggested, it's probably the speaker?.
Nigel Goodwin
Old 18th December 2010, 10:56 PM   #107
chris661's Avatar
Dropping the port tuning might help, though I'd still suspect a lack of available displacement will be the main issue here.
Old 19th December 2010, 12:10 AM   #108
Well, I built the cab to factory specs. I even talked to a factory tech a couple of times while building it.
I'm thinking it may be a defective speaker. I read a review on this speaker where another person was having the same problem as me, farting out at moderate volumes on the lower notes.
On a positive note, keyboards sound fantastic with this speaker. Even when turned up loud enough to play with drums. I've had two other bass players bring their guitars over to try it with the same results. The only way I can get it loud enough to play with drums without distorting,is to turn the treble up and the bass down. Maybe it's just a POS - at least for bass. Maybe I should try the smaller sealed back cab design from the Eminence website? It's tiny though, only about a couple of inches larger than the speaker.
Old 19th December 2010, 10:51 AM   #109
chris661's Avatar
By what you've described, it's the speaker bottoming out. You likely need more cone area, to get the low frequency output you desire.
Old 20th December 2010, 12:06 AM   #110
rock drummers have always been loud, havent they well, and sometimes bass players too
well, its a long time since I played with anyone, and it wasnt bass
but from memory, my estimate is, you will need about 6x 12"
and another guess would be that your Eminence woofer with its 2" voice coil is best suited for the more quiet player
to keep up with a loud drummer, those woofers need to be top pro quality, with bigger voice coils
and lots of amp power
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 05:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 10:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 06:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 03:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 01:17 PM
Copyright 1999-2017 diyAudio
