Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 20th May 2009, 03:23 PM   #1
dave13 is offline dave13  United Kingdom
Smile Speaker wiring help please
Hello please can someone help me - i have no speaker wiring experience and have found what i want on the net but i don't know how to do it. Please could somebody tell me how to wire a Mono/Stereo 412 cabinet with 8 ohm G12's in it. I have attached a wiring diagram which i have found on the net and a picture of my amp with labels and + and - . I have a switch to change from mono - stereo which i think was off a 1960cab - I am wiring a AVT 8 ohm cab which was just mono when bought.
The blurb on the website ( http://www.colomar.com/Shavano/4x12wiring.html ) said this :
Mono/Stereo in same cabinet
4 Musical Intrument Speakers. Mono/Stereo selectable by using a Switch.
**Option 2**
4 - 8 ohm speakers = 16 ohms to each channel if run in Stereo, 8 ohms in Mono mode.
The Right channel jack is completely disconnected when in Mono Mode. Do Not alter this configuration (you risk doing serious damage to your power amps if wired differently).
Mouser Electronics Sells 1/4 inch phone jacks that have a built in DPDT switch - the switch contacts are electrically isolated from the 1/4 inch Jack connection (they have to be in order for you to wire this correctly) - Marshall used this type of Jack/Switch to automatically set the speaker selection mode. They are expensive and prone to failure over time, however, using them often simplifies set-up of your rig. If you decide to use these, the Mono/Stereo switch functionality would be associated with the Right channel, where when nothing is plugged into the Right channel, the cabinet is operating in Mono Mode.
Please can someone instruct me
Thanks in advance Dave
Old 20th May 2009, 04:49 PM   #2
Default Speaker wiring please help
Here's an actual photo of my amp with terminals marked and numbered - so I know exactly where to attach wires if needed
Cheers Dave
Old 20th May 2009, 06:17 PM   #3
Speakerholic
Cal Weldon's Avatar
Are you planning to get rid of the switch and just run it as a 4 speaker mono? If so that's easy. If you still want stereo and can get rid of the switch, that's easy too.
The letter/number system you have used appears redundant. ie: A1+ and A2+ are the same thing. Each terminal can be identified by only one figure.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th May 2009, 09:01 PM   #4
Default Wiring
Sorry I have a switch which switches from mono to stereo like the 1960 amps but the numbers on the back would be different and i understand that.
Is it possible to wire it up so it can be switchable like in the first diagram of the website.
Pic attached of switch
Cheers
Old 21st May 2009, 10:04 PM   #5
Speakerholic
Cal Weldon's Avatar
Yes, just follow the diagram you posted.
HELP speaker wiring conundrum I_Just_Am Instruments and Amps 1 27th February 2009 04:50 PM
Vintage Speaker Wiring 80sboy Multi-Way 5 22nd July 2008 01:14 AM
Mutiple Speaker Wiring louee6 Subwoofers 2 6th April 2007 05:10 PM
Help wiring this speaker The Paulinator Multi-Way 4 26th May 2003 07:02 AM
Page generated in 0.08835 seconds (84.41% PHP - 15.59% MySQL) with 11 queries
