Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 5th April 2009, 08:15 PM   #1
Lightbulb Anyone got a schematic for a ring modulator that DIVIDES?
I want to make a ring mod that divides by the carrier signal to get low harmonics as opposed to high. I was gonna incorporate it in to an enclosure with a multiplying one so I can switch between. Cheers for any help on this
Old 9th April 2009, 02:59 AM   #2
Bitrex is offline Bitrex  United States
The simplest way to get an octave division effect is to first square up the incoming signal using schmitt trigger circuit, and then use a flip flop circuit to divide down down the signal. Then you could feed the output to a ring modulator - you could even put a simple PWM circuit before the ring modulator to control the pulse width of the signal going in. Instead of using one of those diode-transformer ring modulator circuits a simpler way might be to use an IC called a doubly-balanced modulator - they were originally designed to be used in radio circuits but if you feed your audio signal into one input and an oscillator signal into the other you get a great ring modulator sound. The MC1496 or LM596 are examples of this IC. I think DOD made an effects pedal called the "Gonkulator" that used a similar technique.
I'm not sure how "musical" such an effect would sound, but if you're after analog weirdness it's certainly an idea worth trying. Here are some links to get you started:
http://www.play-hookey.com/digital/f..._dividers.html
http://en.wikipedia.org/wiki/Schmitt_trigger
http://www.flashwebhost.com/tcvr/mc1496_dbm.php
Old 11th April 2009, 07:25 PM   #3
Woah cheers I'll get on getting my head round that I was thinking there was just some way of doing it analog and inverting the carrier signal before being put through a ring mod to make it go down cheers though
Old 12th April 2009, 10:22 PM   #4
unclejed613's Avatar
if you had a way of getting some 3rd harmonic, then locking a pll running at 1/2 that giving you a VCO running 1.5 times the input frequency, then put that into the ring mod, you'd get 1/2 your input frequency out (the difference frequencies between F and 1.5F would be 0.5F and 2F) and it would probably sound a bit weird, especially if the response time of the VCO is a bit slow.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
simple ring modulator sheldonstv Instruments and Amps 11 18th January 2011 10:37 AM
BCA modulator design? mzzj Class D 7 9th August 2005 03:35 PM
FM modulator schematics? Tazzy Car Audio 4 18th May 2003 12:26 AM
about the shorted ring (flux stabilizer ring) haggy Multi-Way 3 4th January 2002 03:04 AM
Page generated in 0.08543 seconds (76.49% PHP - 23.51% MySQL) with 10 queries
