Channel Switching - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th March 2009, 05:25 PM   #1
Question Channel Switching
Hi, I have designed a four channel guitar amp and was wondering if somebody could advise me how to implement the switching of channels from the front panel.
I have a load of relays to use and have worked out which relays would need to be on and off for each channel, but I'm not sure how to give each relay the required voltage (5v) from some kind of switch without shorting the other channels.
e.g if channel one needs relays 1 and 2 to be on and channel two needs relays 1, 2, 3 and 4 to be on, then if all were connected to a rotary or toggle switch, if i'm not mistaken only channel two would operate due to shorting. The concept here is to connect one position of a rotary switch to relays one and two, and the second position of the switch to relays 1-4.
There is possibilities of programming a pic to do the work but i've never used these and have a deadline approaching fast so don't fancy learning something new! Does anybody have any other ideas?
Old 26th March 2009, 11:08 PM   #2
There are many ways to achieve what you want. The best thing is for you to look at what others have done.
Here is an example of an amp with 6 channel switching including relay drives, J-FET switching etc., Note that where a relay needs to be active on 2 or more channel selections then "Diode OR" logic function is used:
http://www.schematicheaven.com/newamps/hk_triamp.pdf
You could also view some of the other schematics at that site. This one maybe of interest as well. Trace Elliot generally do their entire channel switching with relays:
http://www.schematicheaven.com/newam..._c100_h100.pdf
Browse that site for further ideas - but those 2 should get you started.
The Hughes and Kettner is quite clever in that channel selection is done by a momentary switch to ground on any of the 6 channel select lines (See page 9). This can be done via front panel switches or footswitches. Note the smaller capacitor value on the base of the Channel 1A select transistor. That ensures that Channel1A is selected at power on.
The Trace Elliot arrangement is simpler.
Hope this is useful,
Ian
Old 26th March 2009, 11:19 PM   #3
Thanks a lot! I think I was heading in that direction but those circuits have definately helped. I was planning on using momentary switches going into SR latches and isolating them from each other using diodes for the front panel. The diode technique should work for other side of the SR latch going to the relays. I'll compare with those circuits you pointed out and see where I end up!
Old 27th March 2009, 12:40 AM   #4
Banned
Default Re: Channel Switching
Yeah, the most straightforwaqrd way is to connect each output position on your rotary switch to each of the relays required for that channel via a diode per relay.
Say, position 1 connects to relays 1 and 2 via 2 diodes, 2 to 1, 2, 3 and 4 via 4 diodes. Obviously the diodes all have to point in the same direction and the direction depends on whether the wiper of the rotary switch is connected to the relay supply +ve or -ve. Each output position now activates the required relays without backfeeding the others through the common connections at the switch. Each relay is now a hardwired OR gate.
You can do a lot of other things, read a pot with a PIC A/D for example, but diode logic is the least elaborate and most economical solution in this case.
w
Old 27th March 2009, 01:00 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Default Re: Re: Channel Switching
w
Hi
1) Don't forget each relay coil needs a freewheeling diode for reverse voltage spike protection.http://www.kpsec.freeuk.com/componen...ay.htm#protect
2) Consider using a common + supply connection to the relays instead of ground. (less likely to short out the supply as it is routed around much less) Reverse all diodes.
3) How about a indicator LED in series with each coil. May adjust supply, but coils have a wide range of pull-in current.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 29th March 2009, 06:50 PM   #6
Thanks for the replies everyone - I will put them to good use!
Old 29th March 2009, 10:05 PM   #7
Hello again- I'm having to resurrect this thread again because I'm having problems still! The concepts shown to me earlier make good sense but I'm beginning to realise that the 10 5V relays I have are going to draw quite a lot of current which I don't really have available.
I have got plenty of surpluss current left over in the heater supply (about 4A worth) but I don't really fancy using that because as far as I'm aware i would have to rectify after the input valve which is going to send more current past the input valve and potentially induce noise.
The bias supply is 50V 0.1A so that is too low current. I was wondering if anybody had any ideas of what I could do here. I was thinking of using the CMOS chips which appear to be a direct replacement for relays.
Old 30th March 2009, 05:23 PM   #8
Banned
TEN 5V relays?
You'll have to post a diagram of the system, or at least specify the signal levels that the 'relays' are switching.
At the moment I can't tell, maybe one is switching the signal at the input, another one is switching power to a module. The power handling required is critical in the selection of solid-state switching.
I like relays in a valve guitar amp. Nice electro-mechanical things. You can get some very small low-power ones. I've got one here - surface mount - Omron G6J-2FS-Y. 30mA in a 5V version. It's 11x6x9h (mm).
10 of these would be 300mA, not a lot of current to pull past your input valve, the additional noise is probably barely audible, if at all. You can test that out fairly simply anyway by just loading up the heater supply temporarily.
You can also mitigate the current draw somewhat with a slightly more sophisticated driver as the holding current is less than the pull-in current, but I'd just be tempted to drive them from a small auxiliary transformer. If you build it this way with the diodes and relays, any half-smart engineer looking at it later will know how it works and you'll always be able to get the parts. Have a look at Rod Elliott's site - the soft-start circuit has some ideas on driving relays.
w
Old 30th March 2009, 06:48 PM   #9
Hi, the relays are all just routing the guitar signal so any relay should do the job. I have ordered a load of goodsky 5v ones from banzai music. The idea of loading up the heater chain is a good idea so i'll try that and see how noise is affected. Most designs ive seen use transistors to drive the relays - will this keep the current draw down? I have considered an auxilary transformer but have very little space left in the chassis - if i find one small enough then that would probably be the best bet.
Old 30th March 2009, 07:30 PM   #10
infinia's Avatar
Hi
10 relays won't all be powered at the same time?
Use your existing heater winding 6.3VAC > 8 VDC and a common dropping resistor. Or even better - a series LED with each relay coil to drop a couple of volts.
Channel Switching Noise with Dish 612 DVR Jon Giard Digital Line Level 0 29th March 2009 03:30 AM
Simple technique for guitar amp channel switching? leadbelly Instruments and Amps 2 2nd September 2008 01:32 PM
DIY amp channel switching AmpKiller66 Instruments and Amps 5 3rd August 2007 03:19 AM
Channel Switching Real McTube? jjai Tubes / Valves 1 22nd July 2005 08:24 AM
Copyright 1999-2017 diyAudio
