Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th March 2009, 11:55 AM   #1
Default Balanced Wet/Dry control
I am trying to figure out how to make an easy to build balanced stereo Wet/Dry control. I want to mix a stereo balanced signal with another stereo balanced signal (namely it will be the compressed signal) and have a pot to control the blend of the two. So I have 12 wires going in and 6 wires coming out.
Any hints? Can I do that with a single multi gang pot?
Old 27th March 2009, 11:16 AM   #2
mjf is offline mjf  Austria
hello.
gainstage one is summing up the signal (perhaps one pot per channel is enough - if not use for every channel a pot)
and stage two (optional) inverts the signal back to phase integrity(if built with variable gain (pot) you can use it as a master volume per channel.....)
perhaps it can help.......
greetings.............
Old 21st April 2009, 11:15 PM   #3
gain-wire's Avatar
I believe you can. excuse me, I should say "I would try that because I in theory it can work"
but you'll need a 4 gang pot, which isn't easy to come by, especially in a 1KOhm to 5kOhm value...
Here is my basic idea:
I don't really understand Franconio's idea, where is the blend pot?
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 23rd April 2009, 04:43 PM   #4
Minion is offline Minion  Canada
The problem with useing a 4 gang pot is that each wafer in the pot won"t have close enough resistance to retain CMRR and a proper Ballanced signal , the Noise performance will degrade which negates the whole purpose of Ballanced signals...
Cheers
Old 23rd April 2009, 04:53 PM   #5
gain-wire's Avatar
Hmm... yeah well there was bound to be something. That's why I said "in theory it can work".
Oh well!
XAR: Digital Balanced Volume Control rhysh Parts 48 15th June 2009 10:33 PM
balanced volume control skaara Pass Labs 99 27th May 2004 03:46 PM
Balanced volume control? MWP Chip Amps 2 1st November 2003 05:36 AM
Balanced Zen volume control Pete Fleming Pass Labs 39 30th August 2002 07:06 PM
balanced volume control diy student Solid State 2 16th January 2002 12:23 AM
Page generated in 0.09086 seconds (72.25% PHP - 27.75% MySQL) with 11 queries
