| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#21 |
Thanks everyone for the help!!
I am still experimenting, but I really appreciate the thoughts. ...PS, now I have feedback disconnected, and a 25u bypass cap on each preamp cathode. It sounds pretty aggressive when cranked now. One comment made me wonder... how does the grid stopper resistor affect the sound? In other words, what kind of tonal changes can I expect by raising or lowering the value? Thanks again everyone!! This forum is great!! |
#22 | |
You probably know this already- the grid stoppers should generally be soldered right to the tube socket lug with the resistor body fairly close to the lug. If necessary you can extend the other 'leg' of the resistor to reach its connection point. Cheers John |
#23 |
Thanks VictoriaGuy for all of your help!
I did not know that the grid stopper resistor should be connected right to the tube socket. I am still very new to all of this and trying to soak up as much as I can. What is the reasoning behind this? Many thanks!! |
#24 |
I can't go into many technical details- I don't know that much! However, the idea is that the grid stopper resistor is preventing unwanted high-frequency oscillations (not necessarily audio, they can be radio frequency range- hundreds of kHz or more). At those higher frequencies, all the wiring has to be much 'tighter' to avoid creating unwanted resistor and capacitor combinations in the wiring itself. Check out the wiring standards on an older (1940-s-1950s) tube radio and you can learn a lot.
A link for you- Aiken Amps is a great resource for all things tube amp- lots of good articles on grounding, etc Cheers John |
#25 |
Regarding the adjustable cathode resistance, you should use a pot in series with a resistor. This way you cannot accidentally short the cathode to ground. I use this setup on mine with a 220 ohm resistor and a 1k wire-wound pot. With this approach, you also ensure that the pot will not be asked to dissipate too much wattage. My pot dissipates about 0.3-0.4 watts this way with the 6v6 biased around 12watts.
Plate-335v Cathode-18.1v Tube watts ~12 Cathode current-39ma Total cathode resistance-465ohm 220ohm Cathode resistor volts-8.6 Pot volts-9.5 Pot Ohms-245 Pot watts-0.37 My previous statement about the stock setup running the 6v6 too hot was more applicable to the Silver Face era and not the Tweed circuits. I have a SF Vibro Champ and that's the one I changed to around 720 ohms on the cathode. |
#26 |
I'm very interested in your preamp section. Could you please send me more readable version? BR, KESRMK |
#27 |
Hi kesrmk, this is the proper sized one.
For some mysterious reason, the Forun only remembers the thumbnail ![]() [image]http://img229.imageshack.us/img229/6...5wcombowa0.jpg[/image] Mind you, that the general design is fine, but the relay switches between random different DC voltages, so it must thump or click big way when switching. Proper DC discharge resistors and an extra DC isolation capacitor should be added to avoid that. More precisely, "clean" signal should be taken *after* C5, where there's 0VDC referred to ground, and not *before* , where there's 173VDC *and* the left side of C9 should be grounded through a 220K to 1M resistor. |
#28 |
If the dirt comes on too early for your tastes that's a common complaint or feature that's a direct result of the extremely low power. I just got one too, still learning about it. Immediately I note that without a master volume you change resistors to alter the percentage of preamp tube distortion versus output tube distortion. Looking at what other people do in modifying these, they often improve dynamic range by reducing hum via dc heater on the first tube or floating the ac filament and adding a bias to reduce the noise from the filament. Then with the noise down, they sometimes add a second single-ended output tube to have parallel single-ended class a. That makes a nice alternative to push/pull but generally requires a different output transformer to make the most of the additional power. Of course, using an extremely efficient speaker in an efficient cabinet is essential to making the clean useful and enjoying toeing the line where distortion first arrives. I've considered modding my champ, but the truth is that it might make more sense for me to pick up a second kit with the features I want. People also make them with a wide range of output tubes.
I'm considering duplicating the output for parallel single-ended class A, but adding a second identical output transformer and changing my speaker impedance. That seems like a nice way to enjoy the class A clean more and expand the area where distortion is just coming on. Last edited by cyclecamper; 3rd December 2012 at 05:50 AM. |
#29 |
All this talk about using potentiometers in odd places has me really intrigued. Not to steal your thread, but I have a question I'd like to ask, or an idea to throw out open for constructive ridicule.
I have a Peavey classic 50 'salvage' amp that I'm experimenting on. I have a 4-gang potentiometer with a lot of space between each of the 4 sections (actually a gear-drive mechanism that drives 4 seperate wire-wound pots in sync, with each pot very conveniently approx. near each stage, mounted in a box where the small reverb tank used to be, now that I have a full-size reverb tank for it). I think each pot section is 20K linear. I wanted to use it on the 4 12AX7 preamp stages. Each stage has its own 150K resistor between the plate and B+. The first two stages have a lower B+ than the next two (in dirty mode) which have a higher B++. So I was thinking of replacing each of those 150K anode resistors with a 135K in series with its own 20K pot, making the combination adjustable from 135K to 155K. Unless somebody can recommend a better range. Then I hope to have a variable regulator for the B+ and another for the B++. And volume pots between each stage, the first two volume pots are push-pull pots that switch a "bright" cap across the pot. That ought to give me plenty to play around with dynamically while listening to it. Last edited by cyclecamper; 5th December 2012 at 01:12 AM. |
| Need advice replacing caps in Harmony H400a guitar amp | tonebrulee | Instruments and Amps | 11 | 22nd May 2010 01:06 PM |
| Some help/advice with a guitar amp layout. | bonescan | Tubes / Valves | 5 | 20th May 2009 11:27 AM |
| 1x10" Guitar cabinet advice | hpl | Instruments and Amps | 3 | 22nd August 2008 10:52 AM |
| DIY Guitar Amp Advice Needed | Trout | Instruments and Amps | 8 | 17th November 2006 03:31 PM |
| Guitar amp speaker advice needed | SY | Instruments and Amps | 16 | 25th April 2005 05:26 PM |
