| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Here are the pictures of my finished bass guitar amp - I build it for my nephew. Some details :
- preamp is from the web page of mister Kreuzer - power amp is two channel build from OPA549 (2 x 25W at 4ohm for home practice) - di output (balanced) made around DRV134 - two outputs direct from preamp The soud is very very good!
Some are born with more and some born with less so don't take for granted the life we've been blessed it's hard to understand thet we're only a guest and each one of us shall be put to life's test. |
#2 |
Another one
#3 |
Last one
#4 |
Wow looks very professional! Did you silkscreen the lettering on?? It looks like it's a manufactured unit! Cheers! I'm sure it not only sounds awesome but looks awesome too!
#5 |
Woah the worksmanship on the enclosure's mint! I wish someone had built something like that for me! What cab do you run it through?
#6 |
@ Test Electrix - the speaker cab are two each one with two 6.5½ FDC Audio woofers (low cost but good sounding) this is for home practice
@ Garp32 - the silk is printed on the paper and then laminated with plastic foil. Laminated paper is then glued with double side adhesive tape on the front and back pannel. The dimension is 320x65 mm.
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| LM3875 Kit Finished - Could use some more bass | johan851 | Chip Amps | 91 | 31st March 2008 01:13 PM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| Finished First Guitar Amp | Sherman | Tubes / Valves | 10 | 20th November 2005 04:01 AM |
| Page generated in 0.07768 seconds (75.66% PHP - 24.34% MySQL) with 11 queries |
