Hi, I have an old Harvard Reverb (~1980 - one of the first solid state amps by fender, a little practice amp) and it is having some troubles. I am looking for a little troubleshooting help.
It plays great for 30-40 min (depending on volume and effects going into it) but then it gets really distorted for a little while and eventually dies. It is then out of commission for an hour or so.
The three options I can think of are:
1) transistor is overheating
2) transistor is fried and needs replaced
3) caps are too old and need to be replaced
Any suggestions on where to start or how to determine which on of these is my problem? I am handy with a soldering iron but don't want to replace parts that are ok.
Thanks for the help!
I'm not that familiar with solid-state amps (I have a tube Harvard), but another possibility is that a so-called 'cold solder joint' has developed on the circuit board over time. As the amp heats up, things move a bit and the contact becomes intermittent.
You can get spray cans of 'Cold Spray' for troubleshooting such problems. On a simple board like the Harvard, it might be as quick to re-solder the board. It just takes a quick touch with the iron to each joint, usually.
Cheers
John
Cheers
John
