diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-amps/)
-   -   Help me out with my organ to guitar amp conversion, please. (http://www.diyaudio.com/forums/instruments-amps/139191-help-me-out-my-organ-guitar-amp-conversion-please.html)
David E H 24th February 2009 12:26 AM
Okay, I'm converting a Hammond AO-35 to a Dr. Z Carmen Ghia.
This is my first build/conversion, so I need a little help. I stripped out the circuit board for the parts, and went to remove all the wires from the tube sockets to clean them up, but then realized I didn't know which power transformer wires were which from the schematic. It doesn't list what colors go where, so I just left it as is.
Here's what you guys have to help me double check:
disregarding the parts, are these schematics the same as far as PT and OT wiring goes?
Also, do those "V"s on the EL84's mean that "4" and "5" are wired together?
http://i549.photobucket.com/albums/i...d_E_H/AO35.jpg
http://i549.photobucket.com/albums/i...hematicfv5.jpg
Another quick question, how exact must I be in replacing caps and resistors as according to the parts list in the "notes" section?
korneluk 24th February 2009 12:38 AM
Re: Help me out with my organ to guitar amp conversion, please.
The "V" represent the tube heaters. To connect them, look up the pin numbers on the bottom left hand side of the schematic, and wire them in parallel to the 6.3V winding of the output transformer where it says "6.3 V to heaters".
The 12AX7/Ecc83 tube can be wired for either 12.6V or 6.3V, so the heaters must be connected in parallel (pins 4 and 5 together) and then connect 4/5 and 9 to the 6.3V transformer winding. Similarly for the 5751 tubes.
Hope this helps,
David E H 24th February 2009 12:46 AM
Re: Re: Help me out with my organ to guitar amp conversion, please.
Hope this helps,
Ah, yes....that helps very much. Thanks so much.
David E H 24th February 2009 07:47 PM
Okay, so do I wire according to the numbers on the tube sockets, or is each tube different in numbering? Maybe I'm over thinking it.
Like, the tube sockets are numbered going clockwise 1-8, but in the tube diagram, the pins are out of order. Is that just for diagramming reasons, or do I have to actually wire them out of order?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
