| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hi all,
I'm putting together a little el84 push pull guitar amp and had a question. If I use a 7600 z primary output transformer will it cause me any trouble? I know the normal load for a pp pair of el84's in 8 k. Will 400 ohms really cause that much of a difference in a guitar amp? Thanks, Nick |
#2 | |
One of my favorite tricks in my guitar amps is th use one of those multi tapped Hammond "universal" OPT's and route every tap to a switch. Each tap changes the load by a factor of two, and even that doesn't change the sound much unless the amp is cranked into clipping.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
Cool thanks, It's what I though but wanted to ask the experts first LOL
Nick |
| Guitar amp question | nhuwar | Instruments and Amps | 32 | 21st January 2009 02:10 AM |
| Guitar amp channel question | Trepan | Instruments and Amps | 3 | 22nd May 2007 03:46 PM |
| Microphone In Guitar amp Question | Trout | Tubes / Valves | 10 | 30th June 2006 02:02 AM |
| Guitar Amp Hum Question | Trout | Tubes / Valves | 5 | 21st October 2005 07:54 PM |
| DC Adapter question for a Guitar Amp?? | lgehrig4 | Solid State | 4 | 20th December 2004 06:11 AM |
