| Instruments and Amps Everything that makes music, Especially including instrument amps. |
My amp doesn't have a switch for the clean and overdriven channels, but I love the amp's distortion. I realized a couple minutes ago that I could build an A/B switch for the amp, but there are a few things that I'm not sure about.
I need to run cables to both channels from the A/B box, but I need to have the A/B box on my pedal board. This means either: 1. I run two cables from A and B 2. I wire A and B to a single, multiconductor cable. If I choose 1, I can just tape the cables together. If I choose 2, I can either run the multi-conductor cable to a splitter box duct taped to my amp, or split the actual cable and solder two mono ends onto it. How would you do it? I'm thinking 1, run the two mono cables, just because then, one cable can go bad, and I'm still relatively good. Plus, replacements are cheap and ubiquitous. This is the best thing to do, right? Thanks for any input. |
#2 |
A(nother) simple way you could do that would be to use some CMOS switching. I have a schematic / board made in Eagle at home (i'm at school right now). I could upload some screenshots, in case you're interested.
I'll get back to you on this a bit later. Chris |
#3 |
OK, just got back home.
The circuit i have is for a "true bypass" thing, but it's easily modifiable to do A/B switching. |
#4 |
What about a passive "A/B/Y" stomp?
Cheers! |
#5 |
Thanks for the feedback. I'm probably just going to make a passive A/B switch that lights up when the distortion channel is selected. I think running two regular mono cables is the best thing, since if one fails, I've got a backup. I'll probably just duct tape them together, or use heatshrink tubing or something.
Thanks again. |
| How to handle very old caps | Bassterror | Power Supplies | 2 | 15th August 2006 10:17 AM |
| Can we handle more zen? | bertjan | Pass Labs | 10 | 31st July 2006 10:04 AM |
| Best way to handle 25hz & down 2 Tempests | johninCR | Subwoofers | 24 | 2nd October 2005 09:31 AM |
| Too hot to handle | Panelhead | Pass Labs | 3 | 8th May 2003 12:10 AM |
| Page generated in 0.08631 seconds (71.16% PHP - 28.84% MySQL) with 10 queries |
